Question about The Computers & Internet
How do I connect this device. it's plugged in and the green lights are on, do I need to do more?
Posted by Joyce Morrissey on
  • Patrik Parker Jul 24, 2019
    Hi Joyce Morrissey, I want to help you with your question, but I need more information from you. Please Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
Troubleshoot no wan green light
Is the wireless working? Can you connect to the Internet? Unplug the ISP modem and the wireless device, Check ALL cables and reseat connections, plug in the ISP modem, allow it to selftest, plug in the wireless device, allow it to selftest, Any change?
Feb 05, 2013 | Computers & Internet
Red light on modem's internet
I think incorrect physical connection between your router device and the PC.Because cable modem status light should be solid green.it indicates that your ADSL/cable modem has a good connection.
Recheck and correct the Ethernet connection between your PC and the router device.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 27, 2012 | Computers & Internet
A problem has occurred when trying to access the internet. Please check your DSL/Cable connection and verify your internet connection settings. Wtf is this ? Firmware update doesnt helped. .
Cables connection might loosen up. Check cables that runs from the wall jack going into your modem, make sure all cables are tightly plugged in. Also, check indicator light on your device. If DSL light is RED, OFF, flashing red, flashing green. there might be trouble with your Internet provider. DSL light indicator MUST be always on STEADY GREEN. If you see that the DSL light is not on STEADY GREEN status call your Internet service provider.
Oct 27, 2012 | D-Link Dlink Dir-600 Wireless Router...
How do I reset s9....the green light stays on constantly and I cannot connect at all.
If you guys haven't found a solution, you might want to try this out. Have your S9 charger hooked up to the unit and plug the charger into a surge protector. Flick the main switch of the surge protector on and off a few times and it should turn off the unit. Then turn on and pair if need to and it should be fine. Hope that works for ya!
Cpl. Ramos
Jun 24, 2009 | Motorola Mobility S9 Headphones
Tom Tom not working
hold the power on button down until it turns on, does this help, also being plugged into charger with green light coming on normally means that the unit is charged.
Jun 21, 2009 | Tomtom ONE GPS Receiver
Flickering green light on power supply
power units not working,, the light means power problem you will need to replace the power supplie
Apr 23, 2009 | Computers & Internet
Three green lights but no internet
It seems that the Internet is not communicating between your device and ISP...
Check if you need to register the MAC address of this device to the provider...
Check the Internet connection to your provider...
Feb 18, 2009 | 2wire HomePortal 1000 Router
I am a computer dummy...How to I connect speakers for sound like music in my computer?
The end of your speakers should have a green plug, on the back of your computer there is a green port. Insert the green plug into the green port. If you have a power cord for your speakers you need to plug that into the wall.
Please rate my answer, and good luck.
Jan 20, 2009 | Computers & Internet
Will not take a charge
I have just the same problem. Initially the battery was flashing to say that it was low on charge even when it was plugged in, then it flashed that the battery was empty and switched itself off. When plugged in the green light comes on, but still cannot turn TomTom 710 on. Also it will not connect to the computer.
Nov 14, 2007 | Tomtom GO 510 GPS Receiver
Computers & Internet Logo
11 people viewed this question
Top The Computers & Internet Experts
Mike 'H'
Mike 'H'
Level 1 Expert
Dakshinamurthy...
gbob59
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
