Question about The Computers & Internet
What are the requirements for midwife - The Computers & Internet
Posted by solomon on
  • Patrik Parker Jul 24, 2019
    Hi solomon , I want to help you with your question, but I need more information from you. Please Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7
IS UNDOCK ENABLED OR DISABLED ?
1. From the Start menu, shut down, then restart the OmniBook.
2. When you see the HP logo, press F2 to enter the BIOS Setup utility.
3. Select the Security menu.
Under Password Required To, choose when the password will be required.
Boot. Requires a password when booting the OmniBook. This option enables the next
two options.
Resume. Requires a password when resuming from Suspend.
Undock. Requires a password when undocking the OmniBook.
See the Manual for more details.
two options.
http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=31634&docId=emr_na-bpi04015&docLocale=en_US
Mar 04, 2015 | HP Omnibook 4150 14.1 in. Flat Panel LCD...
My Beechams Digital Forehead Thermometer is continuously beeping?
Remove the battery and count backward ten Mississippis then reinstall. This should reset the thermometer. If the problem persists, try the same thing again this time clacking your heals together while simultaneously whispering to yourself, "There's no remedy like Home Medicine.....there's no remedy like Home Medicine....there's no remedy like Home Medicine"....
If that doesn't do anything more than earn you a smile and a warm pat on the back from your midwife then I'd throw the piece of garbage into the appropriately environmentally recommended disposal receptacle and buy yourself a trusty old school mercury and glass thermometer like your grand mammy used back when the world was a simpler, less technologically overconvenienced place.
ps...I hope whoever is enfermo feels better asap!
Good luck....
Heal them all Jesus!
Feb 15, 2015 | Home
Upgrading graphics quality on my pc.
There is a large range of graphics card on the market in both performance and prices to match.
The graphic card that suits your requirements depands upon what you want in terms of performance and the application that requires a particular level of graphic capability.
Check the software documentation or games program for the graphic card that is required to run with their program. Generally games programs that require photo realistic rendering require high end graphics cards.
You may select a graphic card that is a bit above your current requirements to cover for future requirements.
I suggest you Google search the Internet or go to your computer shop to see what is available that meets your requirements. You can spend a lot of money on a very high end graphics card when a lessor graphics card would still suit your requirements and not burn a hole in your pocket.
Jun 15, 2012 | Gigabyte Computers & Internet
What do you have to do to become a Wiz in FixYa? I am new and have put in 41 solutions but am still at Master status. When will I be a Wiz and how long until I am a premium expert?
Rank Average Rating Minimum Number of
Solutions Posted guru.gif Guru 85% or higher, 5 votes minimum. 50 wizard.gif Wiz 80% or higher, 5 votes minimum. 30 master.gif Master No Ratings Required 10 expert.gif Guide No Ratings Required 5 nonexpert.gif Apprentice No Ratings Required Rank Average Rating Minimum Number of
Solutions Posted guru.gif Guru 85% or higher, 5 votes minimum. 50 wizard.gif Wiz 80% or higher, 5 votes minimum. 30 master.gif Master No Ratings Required 10 expert.gif Guide No Ratings Required 5 nonexpert.gif Apprentice No Ratings Required You need to visit the Expert FAQ's section to get answers to this, link is http://www.fixya.com/FAQexp.aspx
but here is an extract:
Ranks are calculated by dividing the total value of the ratings cast on an Expert's Solutions by the Expert's number of rated Solutions. Unrated Solutions, Premium ratings, and Live Chat ratings are not factored into Experts' averages.
Wizz needs 80% or higher ranking, 5 votes minumum and 30 solutions minimum.
The help screens are good so just have a look around and you'll find out lots.
Aug 22, 2011 | FixYa Service
I have windows xp o/s, p5vdc-mx motherboard with 512mb ram and 80gb harddisk, can i install windows 7 in this configaration? if no please tell me the configaration?
Windows 7 system requirements 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor1 gigabyte (GB) RAM(32-bit) or 2 GB RAM (64-bit)16 GB available hard disk space (32-bit) or 20 GB (64-bit)DirectX 9 graphics device with WDDM 1.0 or higher driverInternet access (fees may apply)Depending on resolution, video playback may require additional memory and advanced graphics hardwareSome games and programs might require a graphics card compatible withDirectX 10 or higher for optimal performanceFor some Windows Media Center functionality a TV tuner and additional hardware may be requiredWindows Touch and Tablet PCs require specific hardwareHomeGroup requires a network and PCs running Windows 7DVD/CD authoring requires a compatible optical driveBitLocker requires Trusted Platform Module (TPM) 1.2BitLocker To Go requires a USB flash driveWindows XP Mode requires an additional 1 GB of RAM and an additional 15 GB of available hard disk space
If you want to run Windows 7 on your PC, here's what it takes:
Additional requirements to use certain features:
Aug 17, 2011 | Computers & Internet
Does microsoft office and student 2010 work in xp
If you would be planning to use microsoft office and student 2010 on xp you have to have SP3 of XP. You may refer to system requirements given below.
Office Home and Student 2010 Component Requirement Computer and processor 500 MHz or faster processor Memory 256 MB RAM; 512 MB recommended for graphics features and certain advanced functionality.1 Hard disk 3.0 GB available disk space Display 1024x576 or higher resolution monitor Operating system
Windows XP (must have SP3) (32-bit), Windows 7, Windows Vista with Service Pack (SP) 1, Windows Server 2003 with SP2 and MSXML 6.0 (32-bit Office only), Windows Server 2008, or later 32- or 64-bit OS. Graphics Graphics hardware acceleration requires a DirectX 9.0c graphics card with 64 MB or more video memory. Additional Requirements Internet Explorer (IE) 6 or later, 32 bit browser only. IE7 or later required to receive broadcast presentations. Internet functionality requires an Internet connection. Multi-Touch features require Windows 7 and a touch enabled device. Certain inking features require Windows XP Tablet PC Edition or later. Speech recognition functionality requires a close-talk microphone and audio output device. Internet Fax not available on Windows Vista Starter, Windows Vista Home Basic, or Windows Vista Home Premium Information Rights Management features require access to a Windows 2003 Server with SP1 or later running Windows Rights Management Services. Certain advanced collaboration functionality requires connectivity to Microsoft SharePoint Foundation 2010 or to Microsoft Office SharePoint 2007. Certain online functionality requires a Windows LiveTM ID. Other Product functionality and graphics may vary based on your system configuration. Some features may require additional or advanced hardware or server connectivity; www.office.com/products.
Mar 18, 2011 | Computers & Internet
I install flash cs3 in my pc but canot open it
Installation of Adobe Flash CS3
Minimum system requirements
Windows
•Intel® Pentium® 4, Intel Centrino®, Intel Xeon®, or Intel Core™ Duo (or compatible) processor
•Microsoft® Windows® XP with Service Pack 2 or Windows Vista™ Home Premium, Business, Ultimate, or Enterprise (certified for 32-bit editions)
•512MB of RAM (1GB recommended)
•2.5GB of available hard-disk space (additional free space required during installation)
•1,024x768 monitor resolution with 16-bit video card
•DVD-ROM drive
•QuickTime 7.1.2 software required for multimedia features
•Internet or phone connection required for product activation
•Broadband Internet connection required for Adobe Stock Photos* and other services
Macintosh
•1GHz PowerPC® G4 or G5 or multicore Intel® processor
•Mac OS X v.10.4.8
•DVD-ROM drive
Do you system meet the minimiun hardware requirement?
Jul 12, 2010 | Adobe Flash® CS3 Professional Full Version...
Computers & Internet Logo
13 people viewed this question
Top The Computers & Internet Experts
Kelley Hopper
gbob59
EKASYS IT SERVICES
EKASYS IT SERVICES
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
