Question about GPS
The Kluger I am driving continues to give SATNAV guidance despite no phone being connected! WHY I wonder? It's driving me mad. tips please.
Posted by andy watson on
1 Related Answer
rustfarmer
David Harrelson
  • 5440 Answers
SOURCE: Need a wiring diagram for a kluger Please
Go from battery+ to new fuse, to switch, to new relay. Wire relay to provide current to lights when energised.
Posted on Jan 21, 2015
Why does it say can't watch video while driving how do I ignore that on my Soundstream VR-769NB
It is a safety feature so you won't won't drive while watching a video or movie while driving.It makes you wonder why they would even make an up front dvd player with a screen if it is illegal ! (And it is !) So now your parents won't be mad at me because I can't give you the solution to make it where you can see it ! I probably just saved your life and someone else's ! Don't be mad or give me a bad review here I just care about human life enough to not help you get into an accident! Good Luck !
Jan 30, 2015 | Soundstream Car Audio & Video
Tip
How to update your Garmin Satnav maps
To update your garmin satnav map you must have your satnav registered. If it's already registered skip to paragraph 2 below.
1. To Register your Garmin Satnav
  • Connecty our satnav to your computer and go to www.garmin.com
  • Select your country
  • Click on Register your garmin product
  • Follow the prompts
Note you will be asked to create a username and password. Write them down and keep them safe as you'll need them again anytime you want to update your maps
2. To update your maps
  • Connect your satnav to your computer and go to www.garmin.com
  • Click on myGarmin and log in
  • Click on myMaps.
  • If there's an update available it will be shown beside the name of your map.
  • Click on Get Update and follow the prompts.
Note map files are large so you'll need a broadband connection to download them. If you don't have broadband you'll have an option to buy the update on DVD.
  1. If The Map Is Too Large To Install To Your Satnav
    When you go to download the map by default it tries to download it to the satnav i.e. not the SD/Mini SD card. You need to change this. When the website recognises the satnav follow the prompts. It will give you 3 options for the download destination.
    • Download to satnav,
    • Download to Computer and Satnav or
    • Download to computer.
    As the website is updated, from time to time, the method of selecting the download destination changes. Sometimes it shows up as a drop box with a drop-down arrow showing your satnav name. Click the drop-down arrow and select the option to download the map to your computer. Sometimes it shows the 3 options as text headings with tick boxes beside them and you get to tick the option you want. Whichever way it shows up select the option to download the map to your computer. This will install it on your computer's hard drive.
  2. After it's downloaded the map should begin to install automatically. (If not double click on it and it will). It should be allowed to install to your satnav first as Garmin will not allow it to install to your SD/Mini SD card unless it's first partly installed to the satnav. This is so they can ensure that it's installed to the correct satnav.
  3. To Install The Full Map To Your SD/Mini SD Card
    To install the map to your SD/Mini SD card, insert the card into the card slot of your satnav and connect it to the computer. Click the windows start button on your computer. Then click the GARMIN progam and then MAPINSTALL. This runs the map installation program. When the install program finds your satnav and you get the option to install the map there again by default. Click on the drop-down arrow, where it shows your satnav as the destination, and select the drive letter of the SD/Mini SD card. This will be different to the drive letter for your satnav. The map will then be installed to your SD/Mini SD card.
  4. Problems With Older Nuvi Satnavs Reading Maps On 4 Gb Or Higher SD Cards
    When you install a map to an SD card older nuvi satnavs can have difficulty getting the satnav to read it. It will install to it without problem but when you try to operate the satnav then it cannot load the map and will close down the satnav unless you remove the SD card. The reason for this is that 4 Gb and higher cards are SDHC which operate differently from SD. To solve this problem you should use a class 2 SDHC card, which is the slowest type available. You can identify the class by the small figure on the card. It will be either 2, 4, 6, 8, or 10. Before you install the map format the card as described below. Also use webinstaller to check that you have the latest version of operating software on your satnav.
  5. Format the SD card with "Panasonic SD Formatter" available from http://panasonic.jp/support/global/cs/sd/download/sd_formatter20.html rather than the standard windows format function. Select the fast format option and be sure you have selected the drive letter of your SDHC card as it will format your hard drive or indeed your satnav just as easily if you select one of them by mistake.
  6. To update your software or check that you have the latest version, you can download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
    Connect your satnav to the computer and run the program. It will search for any updates to your software.
Class 2 SDHC cards are harder to find in shops today as they are being replaced by the faster classes. They are however still easily available on ebay if you can't find one in the shops.
on Aug 17, 2010 | GPS
Jan 21, 2015 | Cars & Trucks
The external system not connected message appear
You might want to post this question in the automobile section...
Aug 19, 2012 | Koolertron For Toyota Highlander / Kluger...
I need to get updates for ym Garmin nuvi 255w. it did not come with any connection to my computer. I am wondering if I need to purchase at Best buy? How to get updates. I didn't get a manual or anything....
To update your maps you need to connect your satnav to a computer using a mini USB cable. The mini USB end connects into your satnav in the same socket that the car charger plugs into. You might already have one for something else that connects to your computer as many products use the same type of cable e.g. external hard drives, some digital cameras and camcorders, some phones etc. You can get details of how to update your satnav at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
Apr 10, 2011 | Garmin nuvi 255W GPS Receiver
How concect garmin nuvi 205w to laptop
You connect the satnav to your computer with a mini USB lead. It should have come with the satnav. The narrow end goes in the back of the satnav, where the power lead goes in the car, and the USB end goes in a USB socket on your computer.
If you didn't get a mini USB lead with your satnav you may already have one for something else. They come with many digital cameras, camcorders, smart phones, external hard drives etc.
If you don't have one any computer store should be able to sell you one.
Jan 07, 2011 | Garmin nuvi 205W GPS Receiver
My GARMIN nuvi 205WT has stopped talking to me. I have checked the "mute" and it is switched off. The unit shows me the way as I drive and gives audible warnings of speed. How do I get it to speak to me...
1. Press Tools, then press Settings (or Locale on some models), then press Language. You will see a bar for Voice. Press Voice and select a different voice. If this doesn't solve the problem it's most likely because the voice file has become corrupted. To replace the corrupted file.
2. Download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and connect your satnav to your computer. Install webupdater and your satnav will look for updates. After it's finished it will give you an option to download voices. Click the ones you want and press next. The voices selected will be downloaded to your satnav.
When you have removed the satnav from the computer you'll need to select a voice again as described in para 1 above.
Sep 14, 2010 | GPS
My nikon d90 18-105 won't shoot! cannot see live
if you are new to DSLR. set the menu setting default.
however there is lv button to see in live mode.
Dec 27, 2009 | Nikon D90 Digital Camera with 18-105mm...
CONTINUOUS SEARCHING FOR NETWORK
change the settings to automatic network selection
if still the problem exists
then contact ur service provider
Oct 28, 2007 | Samsung SGH-E900 Cellular Phone
GPS Logo
125 people viewed this question
Top GPS Experts
Marvin
Marvin
Tom Chichester
Are you a GPS Expert? Answer questions, earn points and help others
