Question about Exercise & Fitness
What is a L8 serial#u059060 worth? - Exercise & Fitness
Posted by Jason Mcgowan on
My sharp mx 350 shows error code L8 :1 how will i reset it?
L8-01 error should reset itself automatically after repair. This code means something wrong with power supply or power distribution. It is job for experienced engineer, all you can do is reconnect connectors of power supply harness.
Aug 15, 2016 | Sharp MX-M350 All-In-One Printer
How do i fix an landice l8 trainer l5 error
that is a loss of speed error. you only get rid of it when the belt starts moving again
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Jul 22, 2014 | Landice L8 80 LTD Executive Trainer...
What of when 6L is blinking
5 02 Copy lamp lighting abnormalityH2 00 Thermistor open
H3 00 Heat roller high temperature detection
H4 00 Heat roller low temperature detection
L1 00 Scanner feed trouble
L3 00 Scanner return trouble
L4 01 Main motor lock detection
11 Shifter motor trouble
L6 10 Polygon motor lock detection
L8 01 No full wave signal
U2 04 EEPROM read/write error (serial communication
error)
11 Counter check sum error (EEPROM)
12 Adjustment value check sum error (EEPROM)
40 CRUM chip communication
Jul 15, 2014 | Sharp AR-M205 Copier
What year was the a Bulova Diver watch made with serial number: G117649, M8
M8 in the serial number of your watch signifies that it was manufactured in 1968. Here is a list of codes that are used to identify the year the watch was manufactured just in case you were curious.
A8 = 1948
A9 = 1949
L1=1951
L2=1952
L3=1953
L4=1954
L5=1955
L6=1956
L7=1957
L8=1958
L9=1959
M0=1960
M1=1961
M2=1962
M3=1963
M4=1964
M5=1965
M6=1966
M7=1967
M8=1968
M9=1969
N0=1970
N1=1971
N2=1972
N3=1973
N4=1974
N5=1975
N6=1976
N7=1977
N8=1978
N9=1979
P0=1980
P1=1981
P2=1982
P3=1983
P4=1984
P5=1985
P6=1986
P7=1987
P8=1988
P9=1989
T0=1990
T1=1991
T2=1992
T3=1993
T4=1994
T5=1995
T6=1996
T7=1997
T8=1998
T9=1999
Jul 16, 2011 | Bulova Watches
Landice L8 automatically turns on by itself
It is either the control board or the overlay. I would think it is probably the start button on the overlay that is stuck. The solution is to replace the overlay.
Mar 05, 2011 | Landice L8 LTD Cardio Trainer Treadmill
Landice L8 has an L5 error displayed wont start up
is a speed sensor problem or the card connectors are wired specifically where the motor wires, sometimes that part is too hot and breaks the solder
Jul 19, 2010 | Landice L8 LTD Cardio Trainer Treadmill
Error code L8 on XEROX model 5305
That indicates the main board has not sensed the exposure lamps coming on. Those are solder in lamps, I believe there are 6 or 7 on the array.
Mar 01, 2010 | Xerox Office Equipment & Supplies
Exercise & Fitness Logo
120 people viewed this question
Top Exercise & Fitness Experts
Tom Chichester
ray gallant
Marvin
Marvin
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
