SOURCE: rca system link 8av remote How do I turn off closed caption??
CC is usually turned off by selecting an inactive choice,i.e.
If CC1 is on, then try CC2......
Further info ? Please provide Model # of TV.......................T.
SOURCE: Closed Caption
Yeah, I'm now believing it's the tv. The captions on the other tv in the house work great. My samsung is only 2 yrs old. This model was 1080 i...Kinda of costly. Still no solution???? CR. LEE
SOURCE: How do I get to closed captioning on the TV?
You will need the original remote. The TV/CAP/TEXT button turns it on and off. The CH.1/2 button switches between channel 1 and 2 of the closed captioning.
SOURCE: My Vizio 37' flat Screen TV Closed Caption wont turn off
If you have a digital cable box, turn off the box but leave the TV on. Hit the "Menu" button on the front of your cable box and a setup menu should come on. Use the cursor buttons on your box's front panel to go down to the "Captions" option, which is probably set to "Enabled" and hit the right or left cursor button to change it to "Disabled." That should solve your problem.
SOURCE: Unable to remove the closed caption through the
I dont know what model you have i see two on there website. i read manual for one of the 42 inch lcd tvs and i do see where you confirmed you said off to closed caption mode am i correct? Ok try this turn the closed caption on and exit menu. now shut off tv and turn it back on. now go into menu and turn closed caption mode to off now and exit menu and see if that helps. ok i hope this helps ....oh i forgot to mention make sure that you didnt enable the closed captioning on your cable box remote. Just might want to check with that. It might not be your tv at all it could be the cable boxes closed captioning service. I hope some of this helps if not see if there is a factory reset in the menu.
