Question about Furniture
Wine Enthusiast 18 Bottle Dual-Zone Touchscreen Wine Refrigerator (WON'T GET COLD)
Posted by Russell Richardson on
5 Related Answers
Anonymous
  • 27 Answers
SOURCE: wine cooler
cheak the machine main on/off switch, cheak the in$out phase line
Posted on Jun 21, 2008
Sheldon Dedek
  • 912 Answers
SOURCE: Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Posted on Nov 02, 2009
Anonymous
  • 110 Answers
SOURCE: How do I set my
Do you have electronic controls?
Posted on Jan 29, 2011
David Ellis Rhea
  • 3462 Answers
SOURCE: I have a Wine Enthusiast 18 bottle refrigerator Model 2720318. The unit is not getting any power. I have power to the wall plug and the unit is plugged in. Any suggestions on this problem ?
Well, in a word, yes.
Look underneath the refrigerator and see if you can see the compressor anywhere, it may be covered up and you may need to remove a cover to see it.
. If you cannot, you may stop reading here.
If you find it, you should also see a small electrical switching unit mounted on it.
This unit may be the size of your fist.
It should be made of two (2) pieces, one of which is a "Klix-on". The Klix-on is the starter relay for the compressor.
If you find this, take a small hammer and tap on it, whilst the fridge is plugged in and on.
If the compressor starts, you will need to replace the starter relay/Klix-on.
I paid about $ 35 for it at my local appliance parts store.
God bless your efforts.
Posted on Apr 11, 2017
tgmusicgirl
Lisa
  • 101 Answers
SOURCE: My 18 Bottle 2 temp wine enthusiast frig start beeping and blinking
Did you unplug for 10 seconds... then plug it back in?
Do you have any control over the front panel?
Can you verify after all of this, that the back cooling fan is working?
Their is a sensor in the back of the cabinet that monitors overheating of the thermoelectric unit... Unplugging it for a while and powering it back up is one way to verify this...
you can put a fan where the vents are in the back to speed this up...
Posted on Aug 18, 2018
Testimonial: "Thanks for your reply. I did all of that but it did not work. Yes there is digital front control panel and blinking. Also the fans are not working."
Wine enthusiast 269 01 92 03. Temperature is set to 66 F and its freezing all my wine. I lost 8 bottles because the wine froze and corks blew. I just bought it in July 2018.
This is actually a known problem within the wine cooler manufacturing industry. The thermostat has a bad connection, most likely caused by corrosion due to a manufacturing defect. The wine cooler is reading the temperature incorrectly so it thinks it's too warm inside the cabinet and thus continues to try to cool. Although your temperature might read 66°, if you touch the wine bottles they will feel much colder than 66°. It's a simple change of the thermostat and should be covered by your warranty. However, you need to prevent it from happening again so you need to seal the connection point with a hot glue gun to keep moisture out or else it's going to happen again in another 12 months.
Oct 14, 2018 | Furniture
Need a defrost sensor, where can I buy one?
Try a local parts store or you can find it online at repairclinic.com
Nov 16, 2015 | Wine Enthusiast 42 Bottle Double Door Dual...
Wine Enthusiast Silent Wine Refrigerator is making a loud buzzing/whirring noise.
Since this unit doesn't use a compressor, the only moving parts are the whisper fans inside of it that circulate the air. One of those fans may be going bad. If you are handy you can remove the back to see if all the fans are working but your best bet is to use the one year warranty and have a qualified techncian figure it out.
Jan 07, 2014 | Refrigerators
Vinoview #272 02 35 18 wine cooler stopped working and makes a clicking sound
sounds like you have a compressor overheating is it enough air circulation where the unit is located and check to see that the condensing coil and motor are clean too.
Dec 11, 2013 | Wine Enthusiast VinoView Silent 35 Bottle...
Nov 02, 2009 | Refrigerators
Wine cooler
Jun 21, 2008 | Haier HVT12ABS Compact Wine Cooler
Furniture Logo
156 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
