Question about Lands Phones
I have tried to get a hold of the owner who have now blocked my telephone number.
SOURCE: blocking a telephone number
First of all check your mobile security option where is all option about your phone security i think there should be black list option for blank calls if there is no any option like this then you have to contact your franchise where you have got your connection or sim card may be your problem could solve. With best regard M. Khalid Shaikh from Pakistan Mobile: +92-332-2631983
Posted on Jul 23, 2007
SOURCE: I have incorrectly entered my pin number 3 times
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Donot try PUK code many times or else your sim will be blocked and you will need a new sim.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
Posted on Nov 08, 2009
SOURCE: Flashing negative sign
A few suggestions for outdoor flash too bright with SB-600.
1 - If flash is in the auto mode, try hitting the (-) symbol a few times to lower the flash output
2 - Quick fix for close shooting - pull down the diffuser. You loose about 2 stops of flash light and effect is much softer. Don't forget to raise it later or you might think you have the opposite problem
3 - On the camera side, you play with your ISO. Depending on the scene, changing ISO can increase or decrease effect of flash vs background. This can be tricky to predict in auto because the camera is doing calculations of its own.
4 - You can put the camera in aperture mode and set your apeture so that you get a good balance between flash and ambient light. The camera will adjust the shutter speed, which increases or decreases the effect of the background - while the flash remains a constant. This can be very effective in tricky lighting situations, but be prepared to take lots of test shots to get it right.
5 - You can put the flash in manual mode. That will give you a consistant fixed reduced flash output regardless of what the camera tries to change. You have to keep checking your display to see the effect, but with camera in auto this can be a winner.
6 - Finally, you can go "old school" and put both camera and flash in manual and find your best combination. When I'm pressed for time in tricky conditions I often do this by finding a good setiting for a fixed distance, and then adjusting my apeture up or down as I shoot closer or farther things. We had to do it like this back in the day, and with the histogram on the display, I can get dead on where the camera "brain" would get tricked.
Posted on Mar 31, 2010
SOURCE: How do i block a telephone number from my my vtech cordless phone
You can add a telephone number by using Harassment Interception of LEO Privacy, this function is suitable for you I think.
LEO Privacy Applock Hide Safe Android Apps on Google Play
Posted on Nov 10, 2016
You can block it easily by add it into LEO Privacy, I have used it for 1 year. So recommand it to you.
Posted on Nov 14, 2016
Aug 23, 2018 | Garden
Jun 24, 2018 | Garden
May 10, 2018 | Water Garden
Mar 19, 2018 | Homework
Jun 25, 2014 | Tools & Hardware - Others
May 16, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Mar 13, 2009 | Mtd Super Bronco Rt Tiller
118 people viewed this question
