Question about Lands Phones
Is veltech land line phone has intercom in it 6.0
Posted by PALANICHAMY on
4 Related Answers
Anonymous
  • 10 Answers
SOURCE: intercom
Each of the six phones must have line 1 connected to the same "subscriber loop" (the same phone number). Assuming this is the case, and that you have not assigned any numbers to the the top six speed-dial buttons, each station will have agreed to be assigned a station number.
From any station, pressing the speed-dial button for another station's station number will page that station.
Now, how to properly initiate an intercom conversation differs between announcing to another station that a call is on hold, or a "cold call".
Posted on Jan 31, 2008
Anonymous
SOURCE: intercom
make sure each and every phone has its own ID. That solved problems for me for all but one phone.
Posted on May 22, 2008
Anonymous
  • 22 Answers
SOURCE: Intercom
This is a programming issue with the phone .There should be a pull card located in the base of the phone that will give you instructions on how to program the phone.
Posted on Jul 09, 2008
Vit Avaya BP
Vitaly Kagan
  • 211 Answers
SOURCE: System Program & Central Tel Program buttons don't work
This is not a common problem.
Take that phone to a processor and plug it into extension. If no longer seing a problem look into wiring. If problem still there, try a different phone. If different phone works fine you have a bad phone. If problem still shows you have a bad port on a processor. Try available different port. You should really contact your Avaya vendor to fix this.
Posted on Apr 07, 2009
Landline phone constant busy signal
should you dial 9 or another access code for outside calls?
If if you dial an "outside" number on an intercom line it will look at the first 2-3 digits as another extension. You need to dial the Central Office access code, or use a line key assigned to an outside line.
Jan 17, 2014 | NorStar Lands Phones
How do I transfer calls to my mobile as my bt land line is not working
You should be able to contact the phone company for forwarding. If your phone were working you could look up how to do it in your phone book. Most of them publish how to use features like this.
Sep 04, 2012 | Panasonic KX-TG4733B DECT 6.0 Single-Line...
My company has an Avaya phone system that uses Partner 18d phones. When you pick out the receiver the phone would go to one of our 4 outside lines, but recently on ext. 10 when you pick up the receiver it...
http://dstech1.com/changing-the-line-that-is-picked-up-when-you-lift-handset/
All releases of Partner
Lets say that you currently pick up line 1 to make an outgoing call, but you want to pick up your last line (in this case we will say we have 6 phone lines).
This feature is called "Auto line select"
To program Auto line select:
From extension 10 or 11:
Press feature 00
LEFT INTERCOM
LEFT INTERCOM
RIGHT INTERCOM
Enter the extension number of the extension you need changed.
press ** (start, star)
Then the order you want the lines to get picked up
Then ** (star, star) when done
When finished, press feature 00 to get out of programming.
So, in this example I would enter my extension number (22) and press ** (star, star) and press line 6, line 5, line 4, line 3, line 2, and line 1. Then I press ** (start, star) to signify that I am done programming Auto Line Select. And feature 00 to get out of programming.
Easy as pie.
Aug 20, 2011 | Avaya 700340193 Corded Phone
Is there a way to disallow all outside calls and
You could just remove the lines off of that extension:
1.Go to extension 10 or 11
2.Press (feature) (0) (0) (left intercom) (left intercom)
3.Press #301
4.Enter the extension # you want programmed.
5.Enter the line you want removed (line 1 =01 line 2 =02)
6.Press 2 to remove that line
7. Repeat steps 3-6 for all lines you have on that extensions.
Hope this helps!
Sep 01, 2009 | Lucent PARTNER18 Corded Phone
No dial tone on uniden 5.8GHz digital phone
there is no dial tone on my land line uniden 5.8 ghz.
Jan 24, 2009 | Uniden Cordless Phone
Phone ringing.
On extension 10 or 11 press Feature 00
Left intercom, left intercom, right intercom
Enter your extension number
Press line buttons until its a fast blink and display say no ring
Feature 00
only transfered calls will ring
Nov 21, 2008 | AT&T Partner 18 Phone (315805B)
Intercom
May 01, 2008 | RCA 25414RE3 Corded Phone
Lands Phones Logo
121 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
