Question about Lands Phones
How do i turn on voice activated caller id on kyocera 2720?
Posted by joan gallagher on
5 Related Answers
zowl
Gerald Ridge
  • 15 Answers
SOURCE: Caller ID not working
I don't think the problem is the FSK vs. DTMF. The manual even states that the caller ID is generally received after the second ring. This is true in America. I lived in India for four months and I never ran into the problem there so... I just can't say how your provider sends the caller ID. It may be that the line is being interfered with. Do you have a DSL line attached to the same device. If so make sure that there is a filter between you phone and its connection.
I am assuming that you tested your line with the other equipment connected to the same location. You may want to reduce the problem to the simplest configuration by connecting directly to the line only no other equipment. If it works add the other equipment until the caller ID stops again. Then you know what is interfering. If you have a monitor set you could listen to the DTMF being sent make sure it is coming between the first and second ring. It is audible if it is there. If you are answering on the first ring you will not see caller ID you have to wait till after the second ring then you should see it, If BSNL is sending the same as American systems. Good luck Z
Posted on Mar 12, 2008
Anonymous
SOURCE: caller id setting
can i get caller display on this phone ie T7316E if so how
Posted on Oct 10, 2008
consultel1
george peters
  • 860 Answers
SOURCE: Lucent Partner 18D - Caller ID not working
The caller id information is sent from your local telco provider after the first ring and might not be able to be extended to the individual sets, try backing off the ring to answer on your voice mail from 2 to 3 rings to see if the information is then passed on. The Voice Messaging System message is being sent from the system showing who transfered the call to you. You should also notice that the ring pattern when that message is displayed is a standard ring followed by a beep meaning a transfer is taking place.
Posted on Nov 21, 2009
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: how will i activate the caller ID?
What phone system is the 7730 connected to and do you have CID hardware?
Posted on Dec 08, 2009
consultel1
george peters
  • 860 Answers
SOURCE: How can I activate caller
You need a CI trunk card not a LS/DS trunk card for caller id.
Posted on Oct 25, 2010
How do i turn the voice off n my panasonic 6.0 phone
How do I turn off the Talking Caller ID on my phone? To turn off Talking Caller ID on the base;
  1. Press [MENU] [#] [*] [1] [6] [2]
  2. Press the [?] or the [?] button to turn the base Caller ID on or off.
  3. Press [ SAVE ]
To turn off Talking Caller ID on one of the handsets;
  1. Press [MENU] [#] [1] [6] [2].
  2. Press the [?] or the [?] button to turn the handset Caller ID on or off.
  3. Press [ SAVE ]
Note that the base and each handset are programmed individually.
Jan 16, 2018 | Panasonic Lands Phones
How do i. Turn the voice off on my panasonic 6.0 phone
  3. Press [ SAVE ]
  3. Press [ SAVE ]
How can i turn the voice off on my panasonic 6.0 plus phone
Press [ SAVE ]
Press [ SAVE ]
Hello, my phone has been very wierd. when someone calls me, it will have a voice be saying, call from so and so. and i want it to be just a ringtone. please help!
Which phone are you using ? Check your applications if your have installed any software like Voice/Talking Caller Id or something similar . This software will be the reason the Caller id is a voice and not a ring-tone. Even check the settings in ring-tone if you and option to switch off Voice Caller id. Either uninstall the software or disable the software from the options within.
Jan 19, 2011 | Cell Phones
Nov 20, 2009 | Lucent PARTNER18 Corded Phone
I just got this bt8010 have no idea how it works
You have to install the Jabra Control Center, and it will take you through the steps.
Sep 26, 2009 | Jabra BT8010 Wireless Headset
2 Problems: #1Volume fades out. #2No caller ID on Call Waiting
1. move closer to base
2. you must have call waiting ID for that to work at all and most of these phones don't use it during active calls.
go to page 21 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf" if you don't have it) good luck!
Feb 05, 2009 | Panasonic KX-TG1033S Cordless Phone
How to activate the name caller id on supertooth?
Hi Kazgear,
Voice Dial:
Important: Be sure your phone supports the voice dialing function and that it is activated. Record at least one voice tag. (Please refer to the instructions in your phone’s user manual.) Note: Voice dialing entries must be stored in the phone’s memory, not on the SIM card!
1. Press the Accept Button (1) for 1 second.
2. A voice dial beep will be heard on the kit to prompt the user to say the voice
tag of the contact to call.
3. Say the voice tag exactly as how you recorded it.
4. The voice will be played back to you, and then the phone will dial the number automatically.
Her's a .pdf file of the user manual, which you can save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Nov 29, 2008 | Blueant Supertooth Light Bluetooth Speaker...
I have a Panasonic KX-TCA132E but no instructions. I have set up with my phone company for incoming caller id to be displayed, however it is not working. Do i have to use the handset to activate the...
I have had this phone (twin) for quite a few years . If your incoming line supports caller ID it should work immediately. I never had to activate this. I would check if caller ID on your line is working. Check with another phone if you can.
Aug 13, 2008 | Lands Phones
Lands Phones Logo
126 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
