Question about Watches
How to adjust date and day without a bunch of twisting of knob on a tag lynx automatic
Posted by steve hess on
Andrew Taylor
    Top Expert:
  • Watches Master
  • 33,132 Answers
The only way is to twist knobs. Take it to a jeweler or give it to a 12 year old kid to do it for you.
Posted on Jul 24, 2019
5 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: quickly change date on my Tag Carrera
When yoy pull out the crown you will notice there are two clicks. You have to pull out crown to the first click only and then adjust a date by turning the crown.
Rate me, please.
Posted on Mar 13, 2009
Anonymous
  • 11 Answers
SOURCE: Tag Heuer - Aquaracer automatic (Day/ Date)
Actually in the realm of things that is close to midnight. But if you want this changed you will have to take it to a watch repair person because the movement will have to be taken out of the watch and the hands pulled and rest to change when the calender flips over. When I set up watches i usually have the day/date flip after 2 am so that most people never see it change ( because they are asleep lol)
Posted on Jul 31, 2009
David Tolond
  • 2501 Answers
SOURCE: Tag Heuer date adjustment doesn't work.
The date change occurs at midnight, so winding it past midnight changes the date. To change it again wind the hands backward to (say) 11 O'clock) and then forward again will change the date again.
How far you need to turn it back will have to be found by experiment.
Posted on Jan 03, 2010
David Tolond
  • 2501 Answers
SOURCE: cannot pull the knob out, to change the date and
Some watches need to have the crown unscrewed.
Try turning it anticlockwise then pull out.
If this doesn't solve your problem, go to the TAG site "tagheuer.com" and find your nearest dealer.
Posted on Mar 08, 2010
rootbeer001
Roy Limpawuchara
  • 352 Answers
SOURCE: Tag Heuer watch
The knob is a screw-cap seal. When closed (screwed in) it closes the chamber to prevent water from entering the watch.
You will need to unscrew it. It should snap out. In this position, you can wind the watch. Pull the knob out one click, and you can adjust the date. Pull the knob another one more click, and you can adjust the time.
Push the knob back in. In order to seal the watch back up, you will need to push the knob in while turning the knob. You will know you did it correctly when the knob will not turn any further.
Good luck.
Posted on Mar 25, 2010
Instruction manual
Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps .
Sep 01, 2013 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
Time & date adjustment
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TAG HEUER watch manuals. Rate me, please.
Mar 31, 2010 | Tag Heuer Monza Calibre 36 Link Automatic...
How do i change teh date on my tag watch with out having to wind it 24 hours to change one day. i need to change 15 days
If you pull out crown carefuly, you will notice there are two clicks. The first one is for adjusting calendar (day or/and date). Next one is for moving hands. Pull out to the first click and adjust the date by turning the crown.
Rate me, please.
Aug 04, 2009 | Tag Heuer cj1110.ba0576 Wristwatch
Jul 31, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Tag Heuer watch
Good luck.
Dec 25, 2008 | Tag Heuer AquaracerWAF1110.BA0800 watch
Help setting the time
Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps I am actually a car guy (just happen to own a couple)
Nov 06, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
Aquaswiss trax watch
AQUASWISS TRAX MODEL:
For clarity:
There are three adjustment knobs on the right side of the watch. Two are smaller than the main time adjustment knob. For clarification I will label:
Top knob: #1
Middle knob: #2
Bottom knob: #3
To adjust the stopwatch feature:
1. Turn #2 counter-clockwise until it pops out to its adjusting position.
2. Pull #2 towards the right until you feel the first click. (There are two click positions).
3. Simultaneously hold both #1 and #3 down until you see the 1/16 hand and the 30 minute hand rotate automatically to a fixed position.
Now you are ready to calibrate the stopwatch feature.
4. Click mulitiple times on #3 and you will see the 30 min. had move clock wise incrementally with every click. Keep clicking on #3 until the 30 min. hand reaches its apex (to its 12:00 position).
5. Now click multiple times on #1 and you will see the 1/16th hand move in very small increments clockwise. You may be bold and try to hold down #1 and let it swing as close as possible to the 12:00 position and then multiple click #1 to get it precisely to its apex.
You are almost done.
6. Now simultaneously hold #1 and #3 until you see both the 1/16th second hand and the 30 minute hands auto-rotate clockwise to their respective 12:00 positions.
Fantastic! However, now you have to return the watch back to its original locked position. This is where it could get a little tricky.
7. Make sure the time is correct. Using #2 fully extended to its 2nd click position you may adjust the time.
8. Using #2 extended to its 1st click position you may adjust the date. (Here's the trick, do not set the date for today's date. Rather, set it for the day before or in some cases, 2 days before. I will explain in a moment).
9. Now, depress #2 fully back towards the main body of the watch as best as possible and while holding down #2 turn it clockwise until it locks into position.
During this operation you may notice that the date will go forward until the watch locks into position, ergo, I had to make sure the date was for the day before...and it some cases, 2 days before.
Your watch is ready to use.
The stopwatch feature for this analog watch works very similarly to that of an actual stopwatch.
Press and hold #1 once to stop the 1/16 hand. Press and hold #3 to have both the 1/16th second hand and the 30 minute hands return to their 12:00 positions. Now you are ready to race!
Press #1 to start the stopwatch. Press #1 to stop the stopwatch. Press #3 to return the hands back to their respective positions. You may even press #3 after you press #1 to get a second reading but I will let you figure that out for yourself.
Hope this was helpful!
vsndesigns
http://www.rgmarchitect.com
Dec 20, 2007 | Tag Heuer Kirium (CL1212.BA0705)...
Tag Heuer Aquaracer calendar problems
You have to unscrew the knob first then you will be able to pull it out to change the minutes, hours, date. You may have to use a pair of small pliers to initially turn the knob.
Aug 24, 2007 | Tag Heuer cj1110.ba0576 Wristwatch
Watches Logo
187 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
