Question about Seiko Watches
I have a new auto seiko in it has stopped 2 times already ..help !
Posted by Crandall Miller on
Andrew Taylor
    Top Expert:
  • Seiko Master
  • 32,957 Answers
Did you wind it up first before using it. Hold the watch in one hand and and bang on the heel of the other hand. You should be able to hear the counter weight spinning. Do that 20 times.
Posted on Jul 24, 2019
How to get bezel for seiko SQ 50
All parts can be purchased by phone from the Seiko New York call line. They are extremely helpful and get your part as soon as it is available. This is the TRUE Seiko parts line - NOT an off brand. I have used this call line numerous times over the last couple of decades for my husbands Seiko watches. the phone number is:
(201) 529-5730 If they cannot get it no one can!
Jun 23, 2014 | Seiko Kinetic watch
I have 4 seiko watches that no longer work. Most unreliable watch
mcdevito75 here, hello Diane, I'm afraid your jeweler is correct, and so are you. It is adviseable to pull the stem out to save the battery BUT, only if your not going to wear your watch for a long time, not just over night, here"s the problem!! the quartz mechanism and most of the works are plastic, and plastic while fairly flexable when new, gets hard over time, your pulling the stem to stop the watch everyday or even once a week most likely broke the switch in the mechanism that starts the watch, if so your only option is to replace the movement if you can get one. Pull the stem to stop your watch only if your not going to wear your watch for say 2 weeks toa month.
Feb 06, 2010 | Seiko Ladies Two Tone SUJ614 Wrist Watch
I have a Seiko Titanium Chronograph certified water resistant to 20 BAR. The movement # is 7T62-0BZ0. I recently had a jeweller put a new battery in the watch and it has not been working properly since. I...
DO AMASTER RESET TO YOUR WATCH!PULL FULL OUT THE STEM(CROWN)THEN TURN THE HANDS TO THE RIGHT TIME THEN RESET THE CHRONOGRAPH AND THE ALARM WITH THE TWO BUTTONS(SEE YOUR MANUAL.IF YOU HAVENT TRY TO DOWNLOAD IT FROM ANY SITE OF SEIKO SUPPORT).THEN PUT THE CROWN IN.IF THE PROBLEM REMAINS THE ONLY SOLUTION IS THE SIKO SERVICE!THEY ARE NOT EXPENSIVE AND MAKE GOOD WORK!DONT GIVE THE WATCES EVEN FOR THE BATTERY TO THE MONKEYMAGICIANSGURU JEWELERS THEY ARE WATCH RUINERS!
Dec 06, 2009 | Seiko Alarm Chronograph Titanium CASE AND...
Seiko premier chronograph constantly stop working
take watch to a jeweler, or pawn shop and have it cleaned and oiled.
Aug 04, 2009 | Seiko Premier SKP085
Setting time/date on old Seiko
With our 10 year old grandson's help, my husband was able to figure it out. Took a while, but he is now wearing his watch again!
Thanks for the follow-up.
Feb 08, 2009 | Seiko Watches
How to set the alarm on a seiko presage chonograph?
Try Googling (Seiko)(SUY055)(manual) without parens for instructions.
Dec 15, 2017 | Seiko Presage SUY055 Wrist Watch
My seiko kinetic watch stops working overnight but it is fine whilst wearing it
Further to the previous solution...
Despite Seiko's claims regarding never having to change the 'battery', the power storage unit or ECU in Seiko-speak (not technically a 'battery') does eventually need replacing. From the symptoms you describe, it sounds as if the 'battery' on this watch is on its last legs as it is no longer charging properly. The good news is that it doesn't have to be an expensive job to have it replaced (providing you avoid going through the local jeweller <==> Seiko chain!). There are companies on the Internet who offer a replacement 'battery' service. I've used one in the past and was very satisfied with both the cost and the good service. A Google Search will probably return a choice of several in your country. Btw, if you have had your Seiko Kinetic for a few years, its probably worth paying a bit more and having it overhauled (clean and oil the movement and replace the watertight seals) at the same time.
Jul 30, 2008 | Watches
Seiko kinetic
I habe seiko kinetic work and stop work
Feb 07, 2008 | Watches
Watches Logo
129 people viewed this question
Top Seiko Watches Experts
Marvin
Marvin
Gustavo Ortiz
Gustavo Ortiz
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
