Question about Cameras
Zmodo pivot camera... rotats to a point and just clicks fighting some kind of broken gear... I cant figure out how to open it to look inside.
2 Suggested Answers
Anonymous
SOURCE: broken Piece
Waring is a rip off
Posted on Oct 29, 2008
stevenhurc
Steve Hurc
  • 459 Answers
SOURCE: I have a 5spd manual gearbox (from the Diesel
white plastic bush should be on bottom of selector this breaks off or falls off of end ball causing very sloppy gear lever. remove shifter and look for bush on end of selector also look to see if it fell off inside
Posted on Jun 24, 2009
How to reset my Zmodo camera from one account to another
try this site. you have to input more info to get a better answer. there must be 1000 zmodo cameras. so this zmodo forum mayhelp you out. they will insist on more info so get it ready.
This device is registered with another device - Zmodo Forums
Oct 18, 2017 | Home Security
88 jeep wrangler manuel transmission stuck in 1st won't shift at all drives in 1st only like it's locked in gear clutch has pressure
check the lever pivot point in the turret on top of the gear box
they can come loose and the lever doesn't pivot and so will not move the shifter rail
Mar 10, 2015 | Jeep Cars & Trucks
When the camera is turned on and the 16-105 DT 3.5-5.6 zoom is attached there is a repeated clicking sound that continues until the camera is turned off. A sony camera salesman indicated it was the lens. ...
I had the same problem with my SAL-16105. It turned out that inside the lens the FOCUS DIFFERENTIAL RING (Artnr.: 321020202) was broken. The camera tries to move the focus from one end to the other when it is turned on (probably to check the functionality), but as the ring is broken, focus will never reach its end-point. Thus the camera continues to try to turn the mechanics futher until either the gear on the lens ring or one of the gears inside the lens will jump, making the clicking sounds. Another reason might be that one of the brushes ("focus brush") inside the lens that are used to signal the position of the focus to the camera electronics is damaged. (This might even lead to the mechanical destruction of the focus differential ring I think). I was able to repair my ring, but as I had to glue it, after a few months it failed again. I'm waiting for a replacement ring now.
May 15, 2011 | Sony 16-105mm f/3.5-5.6 Zoom Lens for ...
My Samsung S860 will no longer focus and will only take blurry photos. When you press the power button to off, when the lenses retracts, it beeps twice. Is this fixable?
Yes, the problem of your camera still repairable and I hope only adjustment of focus or cleaning of gear inside of the lens.
If you can open your camera and try to adjust the focus gear or clean the gear inside of lens.kindly check alos if the cable is not broken and connected properly.
goodluck and thank you my friend
Jul 17, 2010 | Samsung S860 Digital Camera
My sl 3000 ul gate wont open unless I help it out after i press button on board I have to turn motor shaft and push on gate and then it will catch and opne/close. Is it my motor or my worm gear?
if the motor cant rotate the shaft by itself, its likely a burned coil in the motor, but if the motor is running but not moving the gate then its a broken gear
Jan 24, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
I have a maytag washer model# pavt244aww and it jumps all over the place while it is spinning. any ideas what the problem could be I cant seem to figure it out
There is a stabilizer bar that stretches across the back of the washer, and a pivot point in the right front corner. Both can be accessed through the back panel (tension bar) or top (pivot) of the washer.Look for one end of the tension bar having become disconnected, or the pivot point having become dislodged or broken.
Dec 10, 2009 | Maytag Washing Machines
I have a 5spd manual gearbox (from the Diesel Gemini) and the gear shifter (after being reinstalled) is completely loose, you can get it in to gear (barely) but it's difficult and tricky, the shifter can...
Jun 24, 2009 | Isuzu i-Series Cars & Trucks
Have a powershot sd550
E18 is a lens error. My guess would be sand got into your lens (into the gears, etc.). These guys should be able to take care of you. http://www.darntoothysam.com/servlet/the-1730/Canon-Powershot-SD550-Camera/Detail
Feb 28, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
The camera zoom got jammed
This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 at my shop. Broken drive gears are generally This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 labor at my shop.
Jun 14, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Cameras Logo
62 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
