Question about Hunter Air Purifiers
I would like filters for Hunter air purifier 30447. Do you carry them?
Posted by Joan Hammond on
Tom Chichester
    Top Expert:
  • Hunter Master
  • 57,285 Answers
Fixya does not sell Hunter filters.
Posted on Dec 26, 2019
5 Related Answers
Anonymous
SOURCE: air purifier HUNTER 30200
I hope this is not to late. This is an old post. But I have this same air cleaner. It does prove difficult at first to open and it feels like you are going to break it.
On the sides about two to three inches down is a large indentation. Slide your fingers in there and gently but firmly pull the face plate of the air cleaner off. The air cleaner is as big as the front of the air cleaner. It will slide right out. I hope this helps.
Posted on Mar 02, 2008
Anonymous
SOURCE: lights still flashing after i replaced filter
You have to press the reset button on some models. The unit does not have any way of knowing you reset the filter -- you have to tell it.
Posted on Mar 23, 2009
WatsHVAC
  • 35 Answers
SOURCE: Need manual for Filter Queen 360 Air Purifier
I'm going to go out on a limb and guess you want the Defender model and not the Majestic model. I believe the latter is a vacuum. Here's a link to the Defender 360 manual. Best of luck.
http://www.filterqueen.com/pdf/defender.pdf
Posted on May 27, 2010
Jojo Circus
SOURCE: Homedics AR10 Air Purifier - Clean filter light issues
Please do search before asking question. This one was answered only 20 days ago: http://www.fixya.com/support/t10714206-need_reset_homedics_hepa_air_cleaner
Posted on Nov 26, 2011
Clean air. All day. Every day
    Verified Fixya Pro
    SOURCE: Can I reuse the filters of air purifiers?
    Most of the HEPA air filters which require washing lose their efficiency with each wash leaving you with the only viable option of replacing it with a new filter. In few cases the filter fibers needn't be washed and has extended filter life. Like in the case of a Clair e2f filter which needs to be cleaned using just a vacuum cleaner once a month and lasts for a minimum of 12 months even on 24/7 continuous use.
    Posted on Mar 23, 2015
    Hunter hepatech 40882 uvc air purifier won't turn after cleaned filters
    Hello, this is Ava with Think Crucial.
    Filter life counters should be reset each time the filter has change. If your air purifier has a reset button, press and hold the reset button until the lights go out. You may also unplug your unit from the power for 30 seconds before plugging it back on if your unit doesn't have a reset button.
    You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
    http://www.thinkcrucial.com/search?type=product&q=hunter
    I hope this was helpful.
    Ava B.
    Think Crucial Customer Care
    Oct 24, 2016 | Hunter Air Purifiers
    Hunter air filter when you turn it on it keeps cycling- on/off,on/off and wont stay on. also hepa filter button not working any more, does not light up blue when pressed. TY for any help : )
    If your unit has a reset button, try resetting your unit. Also, replacing the filters and resetting it after putting on the replacement filters usually works. If this fix doesn't work, I suggest you contact Hunter support for assistance and their number is 888-830-1326.
    Ava B.
    Oct 01, 2016 | Hunter Air Purifiers
    Hunter Air Purifier making screaming noise
    Most likely the problem is a bad bearing in the fan motor.
    May 31, 2012 | Hunter Fan Company 30251 Air Purifier
    Owner manual for hunter 30747 Air Purifier
    You may refer to this online manual for your model number to help you put back the filters in your unit.
    Hunter 30747 Instruction Manual
    https://www.thinkcrucial.com/search?type=product&q=hunter
    Ava B.
    May 19, 2012 | Hunter Air Purifiers
    Can I get an owners manual for Hunter 30525 air purifier?
    Yes, manuals are available from Hunter Air Technical Support. Call: 888-830-1326
    Be sure to have the correct Model Number handy, when calling. As some models have been discontinued, but are still supported by Hunter Air.
    Hope this helped you.
    Apr 21, 2011 | Hunter HEPAtech Air Purifier and Ionizer -...
    Model 30375 replace filter light
    There is a "RESET" icon next to the warning light. See the tiny hole? Get a small toothpick or something similar and simply insert, push, and watch the annoying light go out!
    Jun 21, 2010 | Hunter 19' X 21' Room Air Purifier Air...
    Cannot find manuel, need to reset after replacing filters.
    How to reset Hunter quietflo air filter, won't start up.
    Jul 10, 2009 | Hunter QuietFlo 225 Air Purifier
    Lights still flashing after i replaced filter
    Mar 22, 2009 | Hunter (30067) Air Purifier
    Air Purifiers Logo
    217 people viewed this question
    Top Hunter Air Purifiers Experts
    Marvin
    Marvin
    Steve F
    Steven Jeannides
    Level 1 Expert
    Are you a Hunter Air Purifier Expert? Answer questions, earn points and help others
