Question about Kyocera Office Equipment & Supplies
I have kyocera photocopier model2035 it has service error A4200 I can change polygon unit but error not clear plz give me advice
Posted by Shahid Aziz on
  • Patrik Parker Jul 22, 2019
    Hi Shahid Aziz, I want to help you with your question, but I need more information from you.
    Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7/
5 Related Answers
Anonymous
  • 300 Answers
SOURCE: I have a Kyocera c5020n
This what it means (7001 is the error code: 0020988 is the page count) -
Toner motor 4 overcurrent detection
error (black toner)
• The engine controller PWB (KP-1054)
detected the overcurrent of toner
motor 4.
Defective toner
motor 4.
Posted on Jun 16, 2008
Anonymous
SOURCE: c-7 980 error code
i think in km1500 there are no waste ink bottle
may reset in copier its slove
Posted on Jun 29, 2009
M2Tech1
Andy Bell
  • 313 Answers
SOURCE: Sharp AR 163 display L6 error
The error is for the polygon motor if you have done the test for the motor and it doesnt work I think thereis the answer because they spin so fast the motors will eventually go if it had been a little noisy p[rior to this then it has a read or seize error if you know how to take it out youcan manually gently spin it to see if it is stuck just make sure you use a clean dry cloth to cover it prior to turn as you might mark the mirrors.. Good Luck A
Posted on Jul 01, 2009
SOURCE: laser unit polygon motor failure
This error usually means that the laser unit on the machine has failed. Just replace the laser unit part number 116-1110-00
Posted on Oct 22, 2009
Hilton Bristol
  • 567 Answers
SOURCE: hello good day printer is saying
Hi please uninstall the drivers for the printer and reinstall them again,then restart the computer and see if the error still exist.
Please let me know if you have any questions
Posted on Jul 17, 2010
Call Service 7410:0018786 how to I clear this??
The error is for the drum unit, it may just need reseating or changing. The best thing is to take it out, give it a clean and reseat it. Hope this works for you.
Jun 09, 2014 | Kyocera FS-4000DN Laser Printer
How to solve error c4000 for Kyocera KM-2035 copier? it has stopped
c4000
The Problem:
inside the laser unit Polygon motor synchronization problem
The polygon motor does not reach the
stable speed within 15 s of the START
signal turning on
Causes:
1-Poor contact in the
polygon motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable
2-Defective polygon
motor.
Replace the polygon moter or LSU.
May 29, 2014 | Kyocera KM-1505 Copier
Error E100 on Canon iR1024A
Problem with Canon IR1024 Now the screen is reading System Error E100 PLEASE HELP!!
Jan 31, 2013 | Office Equipment & Supplies
Error c4000
This error code means laser unit has the problem.polygon motor inside the laser unit has problem. am sure if you change laser unit machine will work.
Jan 14, 2013 | Kyocera Office Equipment & Supplies
Kyocera taskalfa 180 A-4200
Dear sir,
kindly guide us to clear the Error ..which is reflecting as "Main Power off/on - A4200.."
please do the needful.. ASAP.
Mar 23, 2012 | Kyocera TASKalfa 180 Copier
I have a fs c2126 kyocera printer it gives me c4600 error code
Good afternoon,
Please can someone tell me what is the error C4600 printer kyocera TASKalfa 2551ci?
How can I solve it?
Jul 20, 2011 | Kyocera FS-1118MFP Laser Printer
Getting a E2 error on Kyocera FS-1700+. Any ideas?
this service code belongs to Laser scanner unit (Polygon motor) error
check the connection between scanner unit and engine board .....
Oct 06, 2009 | Office Equipment & Supplies
I need to know what error code A400 means?
a400 is a trouble code for Laser Scanning Unit problem.
Jun 24, 2009 | Kyocera KM-1510 Copier
32 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
