Question about KitchenAid Kitchen Ranges
SOURCE: GE spacemaker Profile XL1800 vent fan will not shut off
It may be a bad door switch, a loose door switch mount, or a problem on the control panel, such as a sticky relay.
I would suspect a sticky relay first, but the door switches should be checked.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
If you need your control panel assembly (smart board) repaired, we do that for $39.95 nationwide.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Dec 02, 2007
SOURCE: kitchenaid oven door will not stay closed
I had the same problem on my parents Kitchenaid KEMS378GWH0 oven, the door would only close enough to keep the light on. They propped a chair against it to cook. My father replaced the hinges and it worked for about a week. He noticed that pulling outward on the door at the very bottom edge often allowed it to close enough to use.
After completely dismantling the oven to get access to the brackets that the hinges slide into, we found it was not broken. We decided to expand on the only near solution we had and find a way to make the bottom of the door 'push out'. Our solution was very simple. Remove the small metal plate that covers the door insulation. This revealed that the insulation is a braided hollow rope that is held in by small clips that push through holes in the front of the oven. We threaded some small metal rods about 3/8 inch in diameter into the hollow insulation pushed the clips back in to re-attach the insulation, replaced the metal cover plate.
It worked!
Posted on Nov 29, 2008
SOURCE: 2005 Chevy Tahoe back door won't stay open...slams shut
no you probably have to change the lift gate struts/supports that are on the liftgate itself. very easy to do and they sell them at the autoparts store i would say for around 30-60 bucks
Posted on Feb 16, 2009
SOURCE: dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Posted on Jan 02, 2012
Here is a tip that I wrote about
the oven door glass replacement...
It is not that
hard...
Range/Stove/
Oven Door Glass Replacement
heatman101
Jan 16, 2011 | KitchenAid Ovens
Jan 08, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Jan 05, 2011 | KitchenAid KHMS155L Microwave Oven
Mar 02, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
Mar 15, 2017 | KitchenAid KHHS179LSS Convection /...
Sep 29, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
Jul 28, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Mar 02, 2008 | KitchenAid KEBC277 Electric Double Oven
Dec 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Jul 03, 2019 | KitchenAid Kitchen Ranges
156 people viewed this question
