SOURCE: Grass clippings won't go into bag
Hello steveacosta:
Check the Blade. If the Lift Area Behind the Sharpened Area of the Blade is Worn, then you will have the Problem you Described.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: Can a mulching blade work in a non-mulching mower?
True Mulching mowers have a specific deck design to them, but I would say yes to your question.It's been quite a few years, but I have done this little conversion myself - replace regular blade with a mulching blade. Just make sure the mulch blade does fit your mower. Also, use something substantial in terms of strength to close the discharge opening. There can be a good deal of force placed at the opening from flying debris. You'll also want to make the cover removable, so you can mow damp grass without the cover.
SOURCE: I have an electrical lown mower model LM 110
IF is it a square plastic washer with 2 "wings\nocht" in the middle you can find at their servicenters because is a very common part and all the Black&Decker mowers use the same one. It holds the blade so you can thighten the nut.
SOURCE: replacement grass catch bag for
It appears that you will need to contact the service center as in your parts diagram, the bag is not listed. A mulching blade is listed, which doesn't require the use of a bag.
http://servicenet.blackanddecker.com/Products/Detail?isId=true&productNumber=MM600&selectedType=4882
