Question about Medical
Ecg100g machine not powering on
I have had machine plugged in for a few days, the power switch and lights are on. the screen is not coming on, I can't do any EKG's because my screen is not on.
Posted by Keisha KeyKey on
5 Related Answers
Anonymous
  • 625 Answers
SOURCE: Machine not heating. Power problems
check inside for burnt spade connectors or wires burnt off the connectors. spade connectors can be gotten from radio shack or electrical supply houses or home depot.
Posted on Sep 11, 2007
Anonymous
  • 472 Answers
SOURCE: acer al1715
Failing capacitors in the power supply will cause this problem and it's fairly common accross all brands.
The parts are cheap, but the labour costs can be high.
If you cannot do this procedure yourself, and also understand the dangers of the electronics, then call several TV repair shops in your area to get a quote, you maybe surprised how much the price can vary.
Just advise them you need to have the capacitors on the power board replaced. It will help them give you a more accurate quote.
Posted on May 27, 2008
Anonymous
SOURCE: only power light will power on for few seconds then flashes.
Does the main lamp light at all? It sounds light a cooling fan failure. If the fan iis not working the the main lamp will not turn on and the power light will flash.
Posted on Jan 08, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: sony kdf50e 2000- green power light turns red what to do
Does red light blink? if yes, please count blinks as there would be pause of 3 seconds between blinks and let me know to help you out.
Posted on Feb 12, 2009
Anonymous
SOURCE: screen stays black green light comes on for a few seconds.
This sounds like you have "bricked" your psp... there are a few things that can cause this: first would be that you have bricked it trying to install Custom Firmware, another would be that the battery died or it was shut off during an update. You can buy what is called a Pandora Battery and a "magic" memory stick which will reset your PSPs firmware to the original 1.5, or if you still have warranty you can send it in to Sony to get fixed. Pandora batteries and Magic Memory Sticks are sold in a package for about $10-15 on the internet. Good Luck, hope you fix it.
Please Rate, thanks!
Posted on Jan 16, 2010
Why won't the machine light up?
Could be controller failure, especially if it has been erratic in the past.
Dec 15, 2017 | Washing Machines
Green LED always on, power switch has no effect
if using a box or receiver in line with the set unplug those as well. I assume the red light on the set is not coming on or a light is blinking?
Dec 18, 2012 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a Fujitsu-siemens lifebook E-7010 laptop. The screen is not lighting up when i switch on the machine. The laptop hums normaly. the green light comes on, but the screen is not lighting up. Please...
You will remove the battery and unplug the dc adapter.After complete those hold down the power switch for 30 seconds.
Now install the battery and plug the dc adapter to laptop again and hold down the power button.I Nhope your problem will solve.
Dec 24, 2010 | Computers & Internet
My e-machine will not turn on....I have put in a new power source, tried a different turn on switch, the power light on the mother board comes on but its as if it is just plain dead...no fans run when youi...
My sister had the same issue with hers. She said one day it died. I replaced the power supply, the little lights on the mobo came on, but the computer did not power up. Come to find out, when the "best-tec" power supply fried, it surged the motherboard and fried that as well. I replaced the motherboard and it works like a charm.
Feb 15, 2010 | E-Machines eMachines Desktop PC
Had trouble booting the computer over time. Sometimes power light would come on and nothing else. By unplugging, waiting 15sec it would power up. Over time this stopped working. Eventually power light...
Time to look for a new computer. That and take out your hard drive to copy your files over.
Sounds like motherboard problem. Probably not worth repair.
I've got an HP desktop with similar problems. It turned on one day just fine. The next day not. I don't even get the boot up screens. Disconnecting Hard Drive and CD/DVD components do not help. I should at least get some BIOS POST beeps and a Hard Drive Not Found or such. I do not. On occassion it will boot to a blank screen with white cursor in upper left. Most the time no screen at all. On rare occassion it comes right on and boots Windows. I guess it could be the power switch ... but I doubt that.
Nov 22, 2009 | E-Machines eMachines Desktop PC
My eee pc 4G surf won't turn on. It started having problems when the power cord was bumped - causing it to immediately shut down. Then it just stopped booting all together. I replaced the power cord and...
Most likely, either the power jack inside the machine (jack itself or solder joints) or the plug on the power cord was damaged; obviously the plug is only a few dollars to replace, the jack also only a few dollars, but much more labor intensive. My experience tells me it's probably the power jack. If you have any way to externally charge your battery and, using it, find the machine operational, that pins it down pretty well. When the external supply is used, the internal battery is supposed to be switched out of the load circuit and into charging mode.
Aug 06, 2009 | ASUS Eee 4G Notebook
HP Media center 1170m
did you checked the ram just clean and fix it again. bye
Oct 01, 2007 | HP Media Center m1170n Photosmart PC...
Medical Logo
178 people viewed this question
Top Medical Experts
Andrew Taylor
Andrew Taylor
Don A
Don A
Are you a Medical Expert? Answer questions, earn points and help others
