Question about Speed Computers & Internet
Hi. Need to replace tiagra 9 speed Tripple as broken. What else will work to get bike running.
Jeff [email protected] Thanks
Posted by Jeff Raphael on
5 Related Answers
Pyrhyc
Ryan Rogers
  • 2028 Answers
SOURCE: Asus a6000 keyboard
Keyboards are most generally held by screws in one of two places. 1- On the bottom, could be marked with a K, With bottom screws, the keyboard may have tabs on it holding it, you will need to pry the tabs gently out away from the plastics. 2- towards the top of the keyboard under the power button strip. Try this link, you may be able to find a breakdown diagram for your machine there.
http://repair4laptop.org/notebook.html
Don't be afraid to remove all the screws on the bottom of the machine if you're unsure as to which are for the keyboard, it won't hurt anything as long as you get them all back in. If they're marked with a B, it's a motherboard screw, and P is for plastic casing.
Posted on Jun 30, 2008
Anonymous
  • 544 Answers
SOURCE: how to repair lcd screen canon powershot sx110-is
hi,
For that camera that died, here are some non-intrusive simple fixes that you should try before throwing in the towel. Copied this first post from somewhere. It was a fix for a Canon A520, but am not sure if it would work for other cameras with the same problem? For those of you with a camera that will not power up or turn on, especially if this occurred after a power interruption with your lens extended, please give it a try. If you do, please leave a comment on specifics like your camera make/model, and whether it worked for you or not.
"DEAD CAMERA, LENS OPEN-If the batteries run down completely while the camera is still open, it may not start up again when new batteries are installed. But if you remove the memory card, then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time."
OK, so the above didn't work. Next thing to look at are the batteries themselves. Are you using alkaline batteries, or worse yet those "Super Heavy Duty" batteries? If so, betcha we've just discovered your problem. Alkaline and regular "super heavy duty" batteries just don't have the power for more than a few pics in a digital camera. Some may even have problems just powering startup of the camera. It doesn't matter if they're new, and right out of the package. Digital cameras for the most part should only be used with rechargeable NiMH batteries (if you still have your instruction manual, open it to the "batteries" section. Pretty sure you'll see a statement similar to what I've just said). Most retailers sell NiMH batteries for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
OK, so maybe those newfangled batteries didn't fix your camera, don't give up just yet. The next thing to check is that your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip.
The next thing to try is examine both the battery and flash card door. There's usually a little switch on both doors (note some SD card doors do not have this switch) that activates when the doors are closed. If they don't, the camera won't start to prevent damage to the flash card or camera startup sequence. For most cameras its usually a little piece of plastic on the door that pushes in on a pin switch when the door is closed. Closely examine both doors to try to identify these switches. A lot of times that little plastic nib wears down or breaks off, but can easily be jury rigged with a small glued-on replacement.
If you've tried all of the above and still no luck, the problem is then likely to be internal to the camera. Am planning on posting sometime in the future some likely things to check, hopefully with a pictoral guide. One example would be that if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
As before, if one of these simple fixes worked in your particular case, please leave a comment on your camera's make, and which fix worked.
Good Luck!
Camera Repair please don't forget to rate our answers..
Posted on Feb 19, 2009
Anonymous
  • 47 Answers
http://digitalcamerarepair.googlepages.com
Posted on Mar 04, 2009
Anonymous
  • 76 Answers
SOURCE: Not spinning
I have found in the past that if the pump is not flowing water, the water level remains too high and the sensor won't allow the spin cycle to operate. I removed the boot from the pump and found several coins, paperclips and a heavy necklace chain wrapped around the impeller. I cleared it and we're back in business!
Posted on Jul 25, 2009
SOURCE: shimano tiagra 9 speed shifters how to change gear
Go to http://techdocs.shimano.com/techdocs/index.jsp
Search in drop down list to go to all tiagra items and identify your particular components. Shimano are good at numbering their parts and you should find the number you seek on the bicycle component. You will usually be able to download an exploded parts diagram and service instructions. The service instructions are prefixed by the letters SI.
Posted on Nov 22, 2009
Big Boy DRT 250 died suddenly
Hi, Chad and the usual suspects are:
1. Severely discharged or a damaged battery must have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
2. Faulty alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Fuel tank empty
11. Fuel tank contaminated with ethanol sludge.
12. Water or dirt in the fuel system, or clogged filter.
13. Restricted, blocked or kinked fuel line.
14. Faulty fuel pump.
15. Faulty pressure regulator.
16. Faulty or clogged fuel injectors.
17. Lean angle switch is faulty or needs adjustment.
For more information about your issue and valuable "FREE" downloads that you need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://www.motosport.com/blog/sudden-*****-dirt-bike-engine-stopped-working
Bike suddenly died on ride today Won start now Speedzilla Motorcycle...
http://cdn.storefront.co.za/stores/big-boy-scooters.storefront.co.za/documents/635971684739856740/big-boy-commuters-drt-250.pdf
Jeff Bikes and Parts Big Boy
https://www.slideshare.net/YunPires/big-boyxtg250ownersmanual
Jul 25, 2018 | Big Motorcycles
02 Neon surges on start - then calms down but surges at idle. Any help would be appreciated. Thank You.
Hi Jeff, I'm glad to help! Jeff, with the engine running tap on the throttle position sensor, If it revs-up when you tap on it then replace it. Hope this helps and have an awesome day Jeff.
Apr 21, 2014 | 2002 Dodge Neon
Washer fluid will not work on 2012 jetta
Jeff, what we find all the time at the dealership mostly is the spray nozzles are stopped up. But on the other hand if you do not hear the pump motor running, then check power and ground. If you have both the replace the pump motor. Hope this helps and have an awesome day Jeff.
Dec 13, 2013 | 1996 Saab 900
My 2004 Harley davidson fatboy runs for about five minutes then shutoff with oil light indicator
Hi Jeff, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below and good luck:
Harley Diagnostic Codes 04 to Present
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 20, 2012 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
Shimano tiagra 9 speed shifters how to change gear
Nov 21, 2009 | Cycling
Jeff Gordon Blender blew up
Sorry to say we do not repair. You will have to contact sunbeam here at this link for service.
http://www.sunbeam.com/index.aspx?section=kitchen
Good luck and Please Rate FixYa1!
Dec 28, 2008 | Sunbeam Jeff Gordon NASCAR 12 Speed...
Pl-600 needle question
Hi Jeff,
Sorry but I don't really have any advice on getting a needle for this turntable. I only know what I've worked on, and so far I've only worked on the belt. Looks like I'm going to have to work on the speed control, unfortunately, I'm not sure how that's going to work out.
Sorry I couldn't be more help, and good luck!
Mark
Jul 13, 2008 | Audio Players & Recorders
Computers & Internet Logo
14 people viewed this question
Top Speed Computers & Internet Experts
Vernon Taylor
Pcm2048
XUNICORNX
XUNICORNX
Level 1 Expert
Are you a Speed Computer and Internet Expert? Answer questions, earn points and help others
