Question about Cycling
Replace counter on Gazelle Edge exerciser - Cycling
Posted by John C Post on
1 Related Answer
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: WHERE CAN I GET A MANUAL FOR THE GAZELLE FREESTYLE
On these units trace the wire going to the frame there is a sensor and on the movable frame their should be a magnet check the proximity of the sensor to the magnet ( should be about 1/8" clearance ). Now if you have the same problem, then you can test this sensor by using a multi meter on continuity setting follow the black connector to the upper board disconnect it and place leads on to connector MAKE SURE you have a good connection when testing. Have someone get on the unit and start using it, the back and forth action should open and close sensor circuit if not replace sensor if operating the the upper console is defective and that needs replacing . Call them @ 800-780-6744 they should be able to help with parts and a manual.
h
Posted on May 31, 2010
Testimonial: "THANK YOU, I FIXED IT FOLLOWING YOUR DIRECTIONS"
Need gazelle edge spare parts
If your machine is not under warranty or you have questions about a replacement part, contact Fitness Quest customer support at 1-800-321-9236 (old number, latest number I find is 1 800 519 8061 in 2017). You can order and pay for replacement parts with a credit card over the phone. The customer service center hours are Monday through Friday, excluding holidays, 8:30 a.m. to 6 p.m., Eastern Time, as of March 2011. Have the model name of your Gazelle Glider, as well as information about the problem and the part that is broken. [email protected]
Sep 11, 2017 | Cars & Trucks
Where can i get new brushes for 24volt motor on a landlex gazelle s420
most any appliance repair shop or auto electrician will have generic brushes that can be trimmed to fit the holder
take a brush to show as an example
Sep 17, 2016 | Health & Beauty
Need prices for parts to gazelle freestyle elite
Try to contact their Fitness Quest customer support for the prices of the gazelle freestyle. Their number is 1-800-321-9236. You can order and pay for replacement parts with a credit card over the phone. The customer service center hours are Monday through Friday, excluding holidays, 8:30 a.m. to 6 p.m., Eastern Time. Have the model name of your Gazelle Glider, as well as information about the problem and the part that is broken.
Apr 23, 2016 | Baby Gear
How do I remove left pedal and replace with new one on Stamina recumbent exercise bike? Thank you!
there is probably a cap of some sort on the outside edge of the pedel you,ll have to remove, with a screw or bolt behind it. look for seam and then pry at it to remove it hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_e9d0abd7cc2508b3
Jan 25, 2013 | Exercise & Fitness
Parts for gazelle edge
Rock Auto has some on sale .
Jan 23, 2013 | Cars & Trucks
h
May 26, 2010 | Exercise & Fitness
Cycling Logo
204 people viewed this question
Top Cycling Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Cycling Expert? Answer questions, earn points and help others
