Question about Sharp Office Equipment & Supplies
My SHARP AR 5618s shows white vertical line in the middle of the page after printing
Posted by Rutuja Shirsekar on
5 Related Answers
Cogz
Chris Coughlin
  • 1326 Answers
SOURCE: Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
Posted on May 21, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: my Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Posted on Jul 20, 2008
Anonymous
  • 3 Answers
SOURCE: Black vertical lines on printed pages
check the "photoconductor unit" (pg 37 in the Maintance manual)
ours was doing it with the magenta and saw a faint 'scratch' on the roller. will attempt to replace and report back if this fixes it.
Posted on Sep 19, 2008
Anonymous
  • 24 Answers
SOURCE: HP colour laser Jet-Print clour problem
Replace the Magenta Toner cartridge.
Posted on Nov 06, 2008
Jim Krause
  • 1779 Answers
SOURCE: Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Posted on Feb 28, 2009
Code for develpoer in sharp ar-5618s
to obtain developer code you should contact the manufacturer
Jun 04, 2015 | Sharp Office Equipment & Supplies
Why is my Sharp ar-5618s showing a green light on the mainboard?
green light on the main board normally mean good!!!! why looking at the main board???
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 07, 2015 | Sharp Office Equipment & Supplies
Please help me, how to reset or clear off Sharp Copier/printer AR 5618s Service Maintenance and Developer Indicator.
try pressing *,#,0,#, 24,2,yes or 1 to reset developer light (circle of dots) Then 20, yes or 1 to reset the little man light.
Dec 19, 2014 | Sharp Office Equipment & Supplies
Sharp AR 5618S Error F2
Hope this help.
Hold down the copy start button
You will get F2 flash then 2 numbers will flash
http://www.manualslib.com/manual/902246/Sharp-Ar-5618.html?page=55#manual
Jul 06, 2012 | Sharp Office Equipment & Supplies
My Sharp copier make a black line right in the middle of the paper.Haw can i fix it?
check first where the source of that black line, print it one page, remove the fuser and copier/developer and trace if mark line is noticeable.
Apr 16, 2010 | Sharp AR-5316 Advanced Digital Imager...
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Black Lines
May 20, 2008 | Sharp AR-BC260 Color Copier
Sharp AR-M280N- Printing dark lines
It sounds like you are going to need a new drum and drum cleaning blade. How long has it been acting up? When was the drum last replaced? The image repeatting could also be coming from the UFR??? It really depends on how many copies you have on it and has it been seatting for awhile..... Need some more info... But you most likely will not be able to fix your self..
May 19, 2008 | Sharp AR-M280N Copier
D-Link Print Server Compatibility issues
DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
Jan 27, 2008 | Sharp AR-5320 Black and White Copier
37 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
