Question about Sharp Office Equipment & Supplies
What will I do with this copier Sharp AR 6020 there a CH Blinking on the screen of the copier
Posted by jianvi Andrada on
5 Related Answers
Anonymous
  • 682 Answers
SOURCE: request service manual for sharp AR-5316
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7b292ec58f421b3b3b442c1437984770&q=Sharp+AR-5316
Posted on Apr 19, 2008
Inno Laur
  • 93 Answers
SOURCE: sharp copier m550n
L4-03 is a lock of the fusing motor. It's likely you need to have the fuser rebuilt. You can try resetting the error by turning off the main power switch (located behind the front door under a little plastic cover) and back on. It's likely the error will come back. There's a cleaning screen on the lower fuser roller which gets gummed up with toner and sticks to the lower fuser roller causing it to seize and the motor not to be able to turn causing the L4-03.
Posted on Oct 06, 2008
Anonymous
  • 115 Answers
SOURCE: Sharp -COPIERS - AR-5316
@subscribe
Sharp does offer a linux driver, look for a cups driver.. Sharp offers drivers for mac, linux, hp output servers, as/400, windows etc... of course this varies on model number...
Posted on Nov 22, 2008
Anonymous
  • 126 Answers
SOURCE: MY SHARP AR-5320E COPPIER SHOWING CH ERROR CODE
Some part/ unit (developer, drum, imaging unit, fuser) or something else is not installed properly or is not plugged into the machine. Check all assemblies that can be removed from the copier, and make sure they are installed and plugged in properly.
The 'ch' code will automatically reset when the fault is found.
Posted on Jan 20, 2009
Anonymous
  • 126 Answers
SOURCE: sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly installed
For the 'CH' check the covers and make sure all covers are closed properly.
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Posted on Mar 03, 2009
Error code ch blinking in sharp 6020 copier.How to resolve this problem ?
ch blinking usually means a door is open. check all doors and latches, all is okay then what has happened is an actuator has bent or is broken.
Mar 07, 2018 | Sharp Office Equipment & Supplies
CH blinking in sharp photo copyier model AR 5520
check if the toner is insert or check the doors for the machine both the front and side door door
Nov 05, 2016 | Sharp AR-5520N
Sharp ar-5320 ch error
Side door open.
-check that all the side doors are closed. ok
Aug 27, 2014 | Sharp AR-5320 Black and White Copier
I have CH Problem in sharp ar 5316 machine. How can I solve my problem?
CH - open cover in the paper feed area CH blinking - Dev unit is not properly installed For the 'CH' check the covers and make sure all covers are closed properly. For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly seated. The developer unit is the unit you slide your ink cartridge into.
May 11, 2011 | Sharp AR-5316 Advanced Digital Imager...
Dears, i have electric problem in my machine SHARP copier AR 5316 it not printing showing (EH) i thing itis electric how can i resolve
CH: i think you mean CH , there is tow type of " CH:
  • blinking "CH" check the toner cartridge and reinstall it correctly
  • steady "CH" check the copier door and close it properly
thank you for using fixya
Mar 06, 2011 | Sharp AR-5316 Advanced Digital Imager...
My sharp ar-5316e error code CH please help me
Hope you are fine, ch are in two forms steady one and the blinking ch.
Steady CH
This is associated with door switch for either front cover or side cover. Check that the front cover of the copier and the right side is well closed.
Blinking CH
This is associated with the toner cartridge or the developer unit not being sensed by the machine. Make sure that the developer unit is well locked in the machine. Pull out the toner cartridge and insert back with some force into the machine, it should clear this sign. If it does not, replace a new cartridge Sharp Ar016ft and you are done. Good luck.
Nov 23, 2010 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Our Sharp AR-N275 copier is displaying error code "CH" (steady, not blinking). What does it mean?
Hello sir; CH it means somewhere the door is open, check it out all the door inside and outside.
Sep 30, 2009 | Sharp AR-N275 Copier
Sharp AR-5330 Blinking "CH"
Here is my site check all the links whenever you have a problem
http://checkitright.spruz.net/?page=dp&dis=834222
"CH" Error Loo k this link for the code
http://www.copier-help.com/copier-help/ecs/sharp/ecssf7800.html
Developper not installed: check wires, contacts, lever
Jul 15, 2008 | Sharp AR-5320 Black and White Copier
Top Sharp Office Equipment & Supplies Experts
k24674
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
