Hi we have a fault please contact me on 0618945285 or 0823318710
Hi - we had a 6 beep code on our 4 stroke 115 - then it ran ok ? after basically shutting down? please help - thank you sensor or bad gas?
year make and model?
guardian - 4 stroke-bhfixejsgpcgsf01t2xxru5o-4-2.jpg if it's Mercury Verado it is telling you you have a sensor fault or a checksum fault. If he problem is gone then it was likely a contact issue with the connectors, all your connections should be opened and dielectric grease applied ESPECIALLY if you run in salt water. If we are talking about a Verado than the contacts in the console must be addressed as well.
Oct 26, 2018 | Boating
What dose code 0002 means in canon mf4410
Hi the only error codei i could find for this model MF4410 printer .,is E202-0002 fault description ::: contact sensor HP error,Failure in return remedy. Check connection of flat cable between main control board (J5) and contact sensor . (2) replace flat cable between (J5) and contact sensor (3) replace the contact sensor (4) replace the main controller board.:::: good luck
May 02, 2016 | Canon Office Equipment & Supplies
Diagnostic red light flashing 9 times on CTM HS 360
hi Leslie, Sadly that is most likely a controller fault...
Please contact me if in the uk as i offer a free testing service...
Regards
Rob
May 02, 2016 | Ctm Health & Beauty
Tampering detected
hi reboot device and check
Jan 24, 2016 | VeriFone Vx 680 Payment Terminal
Hi my Toshiba DVR20 combo plays a vhs tape for 5 seconds then turns self off any advice please
Tape transport mechanism fault. Contact any service technician. Tape do not run properly. Might be the fault of some belt/s or loading wheel.
google.com/+GopakumarGopalan
Jun 29, 2015 | Toshiba DVR20KB DVD Recorder
Tripping rcd when oven gets warm aprox after 10 mins\
Hi this is a pretty serious and dangerous fault, please do NOT use it remove it from the Power, pull the breaker or fuse, and please call a professional electrician. You may have a Phase to Frame contact? In any event, it needs to be serviced.
Oct 12, 2011 | Tecnik TKC8525 Double Oven
F1 error message keeps appearing on my range
Thank you for contacting fixya.com.
You did not mention the brand and type of your kitchen range However please check this link bellow to get a list of error code for your information:-
http://www.repairclinic.com/Fault-Codes
Please get back to us if you have further query else please accept the suggestion.
Jun 02, 2011 | Ovens
Hi I am vince I have a pride huricane when I turn the key and try to go the green light flashes 3 times stops flashing then repetes please help me
Vince the error you have is a motor wiring fault. No quick fix contact the provider that sold you your scooter for help or contact Pride @ 1-800-800-8586 ask for scooter tech support Hope this helps
Mar 16, 2011 | Health & Beauty
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
Hi i use this remote to program my toshiba tv,it work for while ,it stop working.could you me what happen with this remote. thank you.
That is like asking How long is a piece of string!
The batteries are flat
It's got an internal fault
It loses its code
contacts are corroded
and 1000 other faults that may cause it to stop.
The common onbe is faulty batteries and dirty contacts where batteries connect
Best we can do for you
Please rate my help++++Thanks for using FIXYA
Feb 07, 2010 | RCA RCU811 LCD Remote Control
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
