Question about Refrigerators
How to reset f2 after changing fan motor for refrigerator mpr 1014
Posted by kannan on
I have a 2008 chrysler sebring convertable and the computer needs to be reset after changing the thermostat i was told to drive at a set 65 mpr i did that and it would has not reset yet.... HELP
computer doesnt have to be reset after a thermostat change. if your check engine light is on it needs to be scanned for codes. its as simple as that. any autozone will do it for free for you
Dec 28, 2017 | Chrysler Cars & Trucks
What would cause my freezer to freeze, refrigerator not cool, fan in back runs, motor hot
Good Morning Carlene,
I understand the freezer is freezing, in your Frigidaire refrigerator, but the refrigerator portion is not cool. I also see that the fan in the back is running and the motor is hot. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power, stop the alarm, and press the "Factory Default" button. This will reset your temperatures to 37F on the refrigerator side and 0F on the freezer side. Keep an eye on your refrigerator temperatures, to see if they go down. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Refrigerators
Not on wifi
Hi to turn on the wifi you need to press the Fn + F11 keys together
Apr 15, 2014 | Dell Vostro 1014 Laptop Computer
Service manual and parts list is required
Can download at http://www.manualslib.com/manual/149004/Sanyo-Mpr-1014.html
Mar 04, 2014 | Sanyo MPR-1014 - Pharmaceutical...
Factory reset 1014
Hit F2 at boot and then Alt+F or Load Defaults menu option.
Here is a link to the manual - page 64
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_vostro_notebook/vostro-1014_Service%20Manual_en-us.pdf
Mar 11, 2012 | Dell Vostro 1014 Notebook
How can I get the display controls to change the temperature. For some reason our display will not change the temperature. I checked the manual, but it only says what temps to use, not if we have to...
Error Code FFThis is an error code that indicates a failure with the evaporator fan motor but could also be with the main board. If the evaporator motor is running, then the problem will be with the board. If the motor is not running, some voltage checks will need to be made. The problem could be with the wiring to the motor, the motor itself or the board. These can be some complicated checks and will require a technician. One possibility you can try, will be to reset the board. To reset this board, disconnect power to the refrigerator for a few minutes and then reconnect it. If the code disappears and does not return, it should be ok. If it does not go away or goes away but returns again, you will need to replace the evaporator fan motor.
Jan 24, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
How to format DELL Vostro 1014 Laptop
If you wish to FORMAT your hard drive so you can re install the OS.
Put your Windows disc into the CD/DVD drive, boot the computer and press F2 (if that does not work try CTRL+ALT and enter) to enter the bios. Change the boot order to boot from the CD drive first.
Follow the onscreen instructions to Install the OS, you should get the option to delete the existing partitions and then to FORMAT.
Aug 06, 2010 | Dell Vostro 1014 Laptop Computer
Display says hi temperature, wont change when i adjust it. Tried turning it off/on and putting it on factory defaults. Also, air filter change light is on, and water wasn't coming out for a while until i...
Check underneath the refrigerator to see if the coils are clean. If they are covered with gunk, clean them.
Next, check the operation of the compressor (close to the coils mentioned above) and the compressor fan (also near the coils toward the rear of the refrigerator). Both of these must run for the unit to have the proper level of cooling. If the compressor fan is not turning, you will need to replace the fan motor.
Another possibility would be an inoperative evaporator fan inside the freezer unit. However, when this fails, the freezer often remains adequately cold at the top. The refrigerator part does not get cold enough.
Oct 19, 2009 | Electrolux 25.9 Cu. Ft. Side-by-Side...
The remote keeps needing to be reset
I would say the f1,f2,f3,f4, is speeds on the fan motor.If you turn the unit on to cool then I would say you need to keep the fan running all the time.But need to run it med-high or high speed to give good cooling.
Apr 07, 2009 | Heating & Cooling
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
