Heat air tube error on an Dreamscape respiration machine
Posted by George Bale on
Write down the hypothesis for this investigation of cellular respiration in a population of yeast material and equipment
Cellular Respiration in Yeast Video Lesson Transcript Study com
A hypothesis is a testable assertion rather than a question.
It is tricky to narrow the assertion to what is testable.
Are any of the following testable?
Fermentation by yeast occurs without oxygen.
Cellular respiration in yeast converts oxygen into carbon dioxide.
Cellular respiration in yeast converts oxygen into carbon dioxide and glucose.
Sep 01, 2017 | The Kitchen Appliances - Others
Fix error 1e on Samsung wf875
That's a pressure sensor error. The pressure sensor detects your water level.
If you take the top off of your wash machine, you should see a clear, plastic air tube (like the type used for aquariums) going from your outer tub to a sensor mounted on the top right of the washer (well, I think that's where it is on yours. Your model number isn't anything I have in my records). Remove the air tube from the sensor and blow through the tube to clear any obstructions. Then, put the tube back on the sensor and try to run a wash cycle. If the error code pops up again, change the hose and the sensor. If you still get it, make sure you aren't using too much soap and your drain hose isn't siphoning water from the stand pipe. Because, the next thing you are looking at is a new control board.
Oct 20, 2014 | Samsung WF8704RSW
HOW TO FIX A F 35 ERROR CODE
The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor. This error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor. If you are able to unplug the washer and check this air pressure tube, you may be able to resolve this problem. The analog pressure sensor can be accessed by pulling off the top panel of your washer. Remove the screws at the very back of the top panel and then pull it back slightly and then up and off of the washer. The analog pressure sensor is Key 38 in the first image below. With the washer unplugged, check the connection of the air pressure tube to this component. Check the entire air tube down to its connection to the bottom of the washer tub. You will likely need to remove the back panel of the washer to check the entire air pressure tube. If you find a kink, tear, hose or loose connection in the air pressure tube, then this is the likely cause of your F35 error code. If the air pressure tube appears to be okay, then you will likely need to replace the analog pressure sensor. If the problem still exists after replacing this component, then the main electronic control board for the washer will need to be replaced. If you are not completely confident in your technical ability to safely access and check these components, I recommend calling a service technician to diagnose and repair the washer.
Aug 13, 2014 | Kenmore Washing Machines
Getting f35 error code
Hope this helps.
Sep 23, 2011 | Washing Machines
Receiving code F35
The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor. This error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor. If you are able to unplug the washer and check this air pressure tube, you may be able to resolve this problem. The analog pressure sensor can be accessed by pulling off the top panel of your washer. Remove the screws at the very back of the top panel and then pull it back slightly and then up and off of the washer. With the washer unplugged, check the connection of the air pressure tube to this component. Check the entire air tube down to its connection to the bottom of the washer tub. You will likely need to remove the back panel of the washer to check the entire air pressure tube. If you find a kink, tear, hose or loose connection in the air pressure tube, then this is the likely cause of your F35 error code. If the air pressure tube appears to be okay, then you will likely need to replace the analog pressure sensor. If the problem still exists after replacing this component, then the main electronic control board for the washer will need to be replaced.
Jul 10, 2011 | Kenmore Elite 45986 Front Load Washer
My dryer just doesn't seem dry as fast as it used to I just put in a new heating element do you have any suggestions?
The thermostat could be turning the heater off too soon OR the air flow could be restricted inside/outside the machine.
Disconnect the vent tube from the back of the machine to check the air flow. It should blow quite strong. Lint buildup inside the machine can restrict the air flow significantly. Make sure the vent tube and duct to the outside is clear.
Also, check the heat temperature. It should heat up to 130-140 degrees F, cool down to 100-120 degrees F, then repeat.
Apr 06, 2010 | Whirlpool Dryers
Air flow switch is on, service needed and the
have you checked the tubing around the fan?
does the fan come on,
check for restrictions or blockage in the air tube as well as the discharge or flue,
your heater seems to not be getting enough air for combustion to occur.
Jun 12, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
