Question about Head Office Equipment & Supplies
Manual print head alignment is not working - printing includes uneven lines and wavy numbers/letters
Posted by Henrietta... on
5 Related Answers
night71
Lyle Siemens
  • 328 Answers
SOURCE: Print Head Alignment
Get the driver here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14428&prodoid=9935&infoType=Downloads&platform=All
Posted on Oct 29, 2007
techjuli
Juli H.
  • 157 Answers
SOURCE: Everything I print comes out pink, including black print is pink.
Run a clean cycle and a test page this is priming the cartridges. If this fails to get the colors going the printer will need to go in for repair. The internal print circuit could be gone. Check costs before doing this a new printer maybe worth less then the repair.
Posted on Dec 05, 2008
Anonymous
  • 16 Answers
SOURCE: IP4300 lines uneven
reload the driver
Posted on Dec 31, 2008
Anonymous
SOURCE: Z4MPlus Ribbon wrinkles causing lines diagonally across label.
Could be down to tension on the ribbon roller/spool. Check to see if you have pulled out the end part of the spool (black bit) that should ensure there is back tension on the ribbon.
Posted on Apr 11, 2009
Anonymous
SOURCE: black ink not coming through
I had the same problem. Ended up replacing the black/yellow "printhead" and that corrected the problem.
Posted on Jun 11, 2009
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
Wrong cartridge error code on canon pixma mp780 printer
Reseating the print head is seldomly needed to be done.Press the Open Button (1) to open the Paper Output Tray (2) Raise the Scanning Unit until it stops. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.The Print Head Holder moves to the middle Open the Inner Cover 1.Open the Inner Cover 2.CAUTION: a. Do not try to manually move or stop the Print Head Holder.b. Do not touch any metal parts.Press the ink tank's tab (1), then remove it from the slot (2) IMPORTANT:Handle ink tanks carefully to avoid staining clothing or the surrounding area. Lift up the lock lever and take out the print head.Again, place the print head back in position and press down the lock lever. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot IMPORTANT:a. Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.b. If the ink tank is inserted in the wrong slot, perform two head refreshings.Close the Inner Cover 2.Close the Inner Cover 1.Pull the Scanning Unit Lever towards you to close the Scanning Unit.Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.Automatically Aligning The Print Head Position:Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].Press <Menu> epeatedly until [MAINTENANCE] appears.Press left or right arrow to select [AUTO HEAD ALIGN].Press <OK>. The print head position alignment pattern prints.Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete. Manually Aligning The Print Head Position:When automatic alignment does not work well, align the print head position manually.Load A4- or letter-size plain paper in the paper support or cassette.Select the paper source with <Feed Switch> button.Press <Menu> repeatedly until [MAINTENANCE] appears.Use left or right arrow to select [ALIGN PRINT HEAD].Press <OK>. A horizontal pattern is printed.Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.(1): Bad example (Least solid box) 2): Good example (Most solid box) Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.A): Column(0): Select pattern number with most solid image Press <OK>.Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].Press left arrow. A vertical pattern is printed.Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.(1): Bad example (Least solid box) 2): Good example (Most solid box) Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.Press <OK> Repeat steps 12 and 13 to adjust column N.
Oct 09, 2011 | Canon PIXMA MP780 All-In-One InkJet...
My canon pixma 480 has thin horizontal lines. tried cleaning and deep cleaning where is the head alignment tool?
The instructions as copied from the Pixma 480 "onscreen manual." (Only the text -- not the images -- could be pasted into the solution. Hope you can follow the text.) Steve G.
Prepare 2 sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and load 2 sheets of A4 or Letter-sized plain paper in the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Print the print head alignment pattern.
- Press the Menu button.
- Select Maintenance, and press the OK button.
- Select Print head alignment, and press the OK button.
Note: To print the current head position adjustment values, select Head alignment print in the Maintenance menu and press the OK button. See Selecting Menus on the Top Menu Screen.)
- Select Yes, and press the OK button to print alignment sheet.
- Check the pattern is printed correctly, select Yes and press OK button.
- Confirm the displayed message and press the OK button.
The Print head alignment screen appears.
4. Adjust the print head position.
- Check the printed patterns, and use the (Left) or (Right) button to select the number of the pattern that has the least noticeable streaks for column A.
Note: If it is difficult to select the best pattern, select the pattern that has the least noticeable white streaks.
(A) Less noticeable vertical white streaks
(B) Noticeable vertical white streaks
(C) Less noticeable horizontal white streaks
(D) Noticeable horizontal white streaks
- Repeat the same procedure to input the pattern number for each column from B to L, then press the OK button.
- Select Yes to continue printing, and press the OK button.
- The second page of print head alignment sheet will be printed.
- Confirm the message for print head alignment, and press the OK button.
- Check the printed patterns and use the (Left) or (Right) button to input the number of the pattern that has the least noticeable horizontal streaks for column M.
- Repeat the same procedure to input the pattern number for each column from N to R, and press the OK button.
Jan 12, 2011 | Canon Pixma MP480 All-In-One InkJet...
Printing wavy letters instead of straight
we have similar problem. my printer is canon mp 145. straight lines become wavy and some letters are italics when printed out. it was corrected when i used print head alignment but that was true when printing from my computer and not when using the copier. when using the copier lines still comes out wavy and i cannot correct it until now. please post when you solve your problem. i hope it will help you and i hope you can help me
Jan 21, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Vista for canon pixma mp140
Here's the solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Hope this helps - fotobean.
White bands on color photo prints
I hope it helps!!!
Nov 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Will not print 6BK
Please see the Canon link below, and as Canon links return generic pages, type in "missing black print" (without quotes) or something of that nature. The results will include Reseat/remove printhead, among others. I have reproduced that content for you below, but I would also add that a number of folks have issues with black print cartridges, and it seems this is an issue that is fairly widespread, as one of the results is that your printer may need repair. If you have tried more than one cartridge with the same result, suggest consulting support if you don't think your usage justifies a new print head - especially if you are still under warranty. Page link is:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10444
---------------------From Canon-----------------------
Issue: How do I reseat / remove the print head?
Solution: Reseat MP750 / MP780 print head
Reseat Print Head Reseating the print head is seldomly needed to be done.
  1. Press the Open Button (1) to open the Paper Output Tray (2).
  2. Raise the Scanning Unit until it stops.
    1. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.
    2. The Print Head Holder moves to the middle.
  3. Open the Inner Cover 1.
  4. Open the Inner Cover 2.
    CAUTION:
  5. Press the ink tank's tab (1), then remove it from the slot (2).
    IMPORTANT:
  6. Lift up the lock lever and take out the print head.
  7. Again, place the print head back in position and press down the lock lever.
  8. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot.
IMPORTANT:
  1. Close the Inner Cover 2.
  2. Close the Inner Cover 1.
  3. Pull the Scanning Unit Lever towards you to close the Scanning Unit.
  4. Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.
  1. Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].
  2. Press <Menu> repeatedly until [MAINTENANCE] appears.
  3. Press left or right arrow to select [AUTO HEAD ALIGN].
  4. Press <OK>. The print head position alignment pattern prints.
  5. Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete.
  1. Load A4- or letter-size plain paper in the paper support or cassette.
  2. Select the paper source with <Feed Switch> button.
  3. Press <Menu> repeatedly until [MAINTENANCE] appears.
  4. Use left or right arrow to select [ALIGN PRINT HEAD].
  5. Press <OK>. A horizontal pattern is printed.
  6. Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
    (2): Good example (Most solid box)
  7. Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.
    (A): Column
  8. Press <OK>.
  9. Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].
  10. Press left arrow. A vertical pattern is printed.
  11. Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.
  12. Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.
  13. Press <OK>.
  14. Repeat steps 12 and 13 to adjust column N.
Please post back if you need additional help. Otherwise, thanks for rating FixYa!
May 15, 2008 | Canon PIXMA MP780 All-In-One InkJet...
23 people viewed this question
Top Head Office Equipment & Supplies Experts
ray gallant
Troy Staley
Troy Staley
STEVE SPAM REMOVER
Are you a Head Office Equipment and Supply Expert? Answer questions, earn points and help others
