I had a power surge and now my Splendide RV washer wont turn on. The circuit breaker was flipped, but the dryer works.
Posted by Stacey Hill on
5 Related Answers
robert samples
  • 1314 Answers
SOURCE: oven sparking problem
i think you will find the power cord is burned this happens if it wasnt tightend up properly and gets loose turn the oven breaker off before you pull it out
Posted on Jan 24, 2008
James Chandler
  • 686 Answers
SOURCE: where is circuit breaker in a LG DLE9577WM dryer
it could be the thermostat it could be a burned heat element if electric verify gas or electric
Posted on Mar 06, 2009
Anonymous
  • 77 Answers
SOURCE: dryer kicks off circuit breaker, pf code is on dryer. now won't let me do anything
pf is for power failure. sounds like You may have a short somewhere. Be careful of electric shock.
Posted on Apr 21, 2009
Anonymous
  • 998 Answers
SOURCE: our frigidaire oven (model #FEF-366-CCC) shut off
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Posted on Aug 22, 2009
emissionwiz
Marvin
  • 85239 Answers
SOURCE: I have a splendide 2100 washer/dryer, I have no
there may be a thermal limiter inside the washer, remove th back cover to see it if it does have one.
Posted on Sep 05, 2009
Why wont my Splendide washer/dryer wont turn on?
check outlet for power if ok bad switch or transformer make sure on 120 volts
Jun 13, 2014 | Splendide Washing Machines
Plugged into bad electric, Washer/dryer combo does not power on now
if your appliances all blew they may have been fuse protected, such as tv's and microwave have inside them. Power converter should be fuse protected as well. If the plug was wired incorrectly was it a fifty amp service or thirty? Does your power run threw a transfer switch? look there as well. typically voltage spikes threw ground circuits take out your electronics. Using ground fault interruption circuits and voltage protectors in between your plug and power supply will prevent most/some damage. many variables to pinpoint without input.
Nov 11, 2012 | Splendide 2100 Front Load Washer / Dryer
My RV Washer/Dryer combo takes extra long to dry my clothes. Could the vent be plugged? It seems to be taking twice as long as it normally did before. How do I clean the vent? Can I get to it from outside?...
if you know were the vent is at from out side, then yes use a cloths hanger end of it hooked or you may want to try vacuming it out is there any othere felter screens on dryer please unplug before working on it or turn off breaker to it.
Nov 24, 2009 | Splendide 2000S Vented Washer/Dryer
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Broken door handle on Splendid 2100 RV Washer/Dryer Combo
The Splendide distributor in OR sells handles for about $45.
Jan 27, 2009 | Splendide 2100 Vented Washer-Dryer
Splendide 2000S
www.splendide.com
1-800-356-0766 #5 (503-656-2280)
503-722-9202
[email protected]
Monday-Friday, 7:00am - 4:30pm (PST)
You may also want to try a RV retailer in your area, they may direct you to a used part.
Jun 10, 2008 | Splendide 2000S Vented Washer/Dryer
Non-operational in RV when Onan generator and Xantrex inverter are on
Are you still under warranty with your RV? If so, take your RV back to them and try to get this problem fixed through them. You know more about electronics than I do (LOL) however, I do believe the RV sales/repair should be taking care of this issue for you.
I on the other hand own the Majestic brand washer and dryer and I am very dissapointed with them. The washer is broken already and is only 15 months old. Ugh!
Good luck, I hope your issue is a simple fix.
Oct 28, 2007 | Splendide 2100 Vented Washer-Dryer
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
