Question about Refrigerators
It keeps kicking out gfi, problem is we were going to use it in areas that only have gfi outlets. Will this unit not work on an gfi receptacle?
Posted by Allan Apple on
5 Related Answers
Anonymous
SOURCE: WC1000 GFI
You're not alone.  Same problem here.  Breakaway power cord on my Waring deep frier burnt to a crisp.  Don't known about you, but I'll never buy Waring products again.
Posted on Oct 12, 2007
Anonymous
  • 706 Answers
SOURCE: Keeps tripping GFI outlets
The key here is to identify the problem as being either the coffee maker or the GFI receptacle... a simple test can be done as follows...
Try plugging the Coffee Maker into another GFI receptacle .. you may have one in the bathroom? If it trips that too, then you have an internal wiring problem with your coffee maker.. if it doesn;t ..then your GFI receptacle may be bad or on the verge of going bad .. either way..this should narrow the problem down to one or the other.. hope this helps..
Posted on Aug 31, 2008
Anonymous
SOURCE: when radio is plugged in only the gfi outlets work not the radio.
Mines similar, outlets work but radio will only work on battery. Radio will not work on mains only. Charger works at same time so ok. SORTED IT TONIGHT. Inside the charger inside the box there is a fuse (240v 2A) I think, tiny radio fuse. Changed that tonight and radio now works on mains only or battery. Very awkwark job but better than watching a load of cr** on tv. Hope this helps someone.
Posted on Aug 18, 2009
logcabinsam
  • 7 Answers
SOURCE: ground fault interrupt (GFI)
I have a Whirlpool Model AD$)DSR1 Dehumidifier, with similar issues. When plugged in where it was operating for three years with no problems, it would trip the gfci within 10 minutes. I have it out in the garage right now with all the covers off, and I've had it running on a heavy duty outlet for about a half hour now. The compressor is too hot to touch (ouch!), and the condenser coils are only cool, when they should be quite cold. I am ready to judge that one of two things has happened: Either the compressor is bad, or the refrigerant has leaked out of the system.
Posted on Aug 27, 2009
kirkx
Kirk Augustin
  • 2019 Answers
SOURCE: Our Keurig keeps kicking off the GFI outlet when
This is not an exact science. The GFI is trying to trip when it thinks you have a dangerous short. But a powerful device will require a surge when it starts up that is always pretty close to what appears to be a dangerous short. You could switch the GFI out with one rated higher, like 20 amps instead of 15 amps. It would be harder to tell if the Keurig is drawing excessively, because it would only be a transient, for a fraction of a second. You would almost need an oscilloscope to tell what it was doing accurately.
My advice would be to try a surge protector, such as:
http://www.hardwareandtools.com/invt/u720584
The idea being that a surge protector has capacitors in it, to slow down or clip rapid current flow or voltage build up. Which should reduce any eroneous tripping. Basically this one is a plug in version of what you have in the wall, but higher quality and easier to install.
Posted on Jan 22, 2010
25 ft 2004 komfort trailblazer travel trailer. Bumper pull. I have no power to any wall plugs. Changed GFI plug in bathroom. Keeps popping rite away. How do I find and solve this short?
it is a dead short in the wiring
if the plug is anything other than 12 volts -call an accredited electrician
just because it is a trailer doesn't mean that the voltage will not do serious damage top your health
Jan 10, 2017 | RVs
When activated, the thermostat stays on for about 45 sec. and then kicks out indicating a gfi problem . . . this seems far too sensitive . . . can I override this in some manner?? Thanks, Wayne
You can replace the wall outlet with a GFI type and cut the ac cord end off and install a basic 3 prong for 120 volt system. AC unit controls don't like ground faults and should be corrected. The cord gfi may be going out.
Apr 03, 2015 | Heating & Cooling
Our Magic Comfort plus is 4 years old and it keeps blowing the gfi instantly when I plug it in. I have had this problem occassionally in the past and it resolves after one or two gfi trips. Now if tripo...
The problem believe it or not your gfi is warn out. I am actually surprised it lasted as long as it has and surprised it worked at all. Espresso machines use a huge amount of power when turning on compared to maintaining power. When espresso machines first turn on the take a huge surge of power to start heating up the elements. Normally you want to put an espresso on a circuit /outlet that is directly to your breaker that is at least a 20 amp breaker. By code kitchens and bathrooms, where an outlet is near water, has to have a gfi outlet, this is for safety for something plugged in near water so it will trip if accident happens with appliance near water. The bad news there not to good with high demand power appliances such as espresso machines. Yes , you can replace the gfi circuit, by turning off main breaker, unscrew gfi from wall, pull out, and undo wires, and copy exactly when re-wiring the new one. Then turn on main breaker again. NOTE: you can buy a gfi all most any home improvement center, lowers, home depot, ace hardware etc.... Think of a gfi kind of like a advanced in line fuse, they do wear out. BUT AGAIN, my advice is plug it in a outlet that does not have gfi and is on a main breaker of at least 20 amps if you have that opportunity to do in your kitchen area. Hope this helps you, thank you....... MIKE
Jul 26, 2011 | Saeco Magic Comfort Plus Espresso Machine
GFCI keeps poping when I turn on the dishwasher
Sounds like your electrician miswired your GFCI oulet. They probably pulled power for your dishwasher off of the 20 Amp small appliance circuit required in all kitchens. This could be simple or difficult to fix, depending on where exactly they pulled power from. You will need to trace the dishwasher wire back to find out which receptacle box they pulled power from. If they pulled it from the first GFI outlet, you're in luck. Simply pull out the GFI and move the dishwasher pigtail from the LOAD side of the GFI to the LINE side of the GFI. If they pulled the dishwasher circuit from a receptacle downstream of the GFI, you will have to pull a new circuit for the dishwasher from somewhere else, as switching the branch circuit from LOAD to LINE at the GFI would defeat the ground fault protection for all outlets downstream of the GFI. Before doing all this, make sure there are no shorts to the frame of the dishwasher that could be causing the GFI to trip in the first place. If you need more detailed instructions, let me know. I'd be happy to walk you through it.
Apr 29, 2011 | Dishwashers
My DW384 circular saw keeps tripping the GFI receptacle
Most houses have all the outdoor GFI outlets on one breaker...perhaps you can try another power tool with a similar draw to check if it is your saw or the GFI causing your problem. I can't see bad brushes causing a breaker to trip... the saw would just stop working.
Jun 20, 2010 | Dewalt 814 Inch Circular Saw
I have a question on Coleman AC
First of all, an extension cord and GFI receptacle to run an AC unit will almost always blow either GFI or circuit breaker or both due to large current draw from AC unit. If an extension cord needs to be used, keep it as short as possible, and use the heavier gauge that is approved for AC use. What happens when you use an extension cord, is the voltage drop that will happen by the time the AC gets power. With any voltage drop, the amperage draw increases, so a 15 amp circuit breaker will most likely trip. Nowadays, all AC units are wired with a minimum 12 gauge wire rated for 20 amps.
You say nothing is happening now, is that to say that the fan only mode doesn't work on the AC unit either?
Apr 26, 2010 | Dometic Rooftop RV Air Conditioner
My refrigerator keep popping the electric outlet
What do you mean by "popping"? If you are plugging it into a GFI receptacle it will do that. Use a different receptacle. If it is popping the circuit breaker, you may have an electrical problem in your house.
Dec 30, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Kenmore 417.40412700 triping GFI receptacle
Amperage pull too high. Increase the rating of the GFCI outlet - or there i an issue with the washer itself.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 19, 2009 | Washing Machines
Kenmore 417.40412700 tripping GFI circuit breaker
Unfortunatly washing machines are too sensitive for GFI outlet.only way to fix is too take it off the GFI.
Mar 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Aug 30, 2008 | Keurig B60 Coffee Maker
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
