Question about Rancilio Coffee Makers & Espresso Machines
I have a rancilio Silvia. when I turn on the button for the steam wand, as it begins heating up it sprays steam into the water reservoir tank. I have tried descaling and backflushing. Any suggestions?
Posted by Dave OHara on
Gary F
    Sergeant:
  • 236 Answers
My guess is the steam wand is clogged with milk. This is a common problem. Try a pipe cleaner or something similar.
Posted on Aug 06, 2019
  • Dave OHara
    Dave OHara Aug 19, 2019
    thank you for the suggestion! I had tried that as it was my first suspicion as well. For those interested, the problem was that the gasket on the piston on the 3-way valve was deteriorating. $10 fix and it's working beautifully! Thanks again!
5 Related Answers
Anonymous
SOURCE: water will not come through the steam wand
I had the same problem. I took the steam wand off, and checked for steam out of the unit. It was OK, so I stuck a thin wire up through the steam wand and dislodged what look like pieces of a green washer or O-ring.
In short...the wand was plugged.
Posted on Feb 03, 2009
bansheracer
  • 1089 Answers
SOURCE: no water through group head
Hi
More than likely your 3 way valve is stuck. It is located behind the front panel and when the 2 screws are removed it slides to the right. Unplug your machine before working on it. The 3 way valve is on the left and you can remove the dispersion tube on the bottom(unscrews) 14mm nut holds the solenoid on and you can slide the solenoid down the shaft. The big nut at the top of the shaft will unscrew and there you will fin the solenoid inside with a big spring. If its not stuck it will slide out and you probably need a new 3 way valve, but more than likely its stuck. Some times just tapping the nut on something hard will unstick the solenoid. Clean good and reinstall.
Posted on May 26, 2009
co7196
Ned C Cook
  • 3433 Answers
SOURCE: steam wand doesn't work
High pressure air using a blowgun?
Posted on Aug 24, 2009
EsWorld
Ernest R
  • 1618 Answers
SOURCE: Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Posted on Jan 21, 2010
EsWorld
Ernest R
  • 1618 Answers
SOURCE: Rancilio Silvia: The steam works only for about 10 seconds
Remove the top panel and check the 3 thermostat on the machine one of them is not functioning properly, find the wire to the steam switch and trace it to the thermostat.
Posted on Jan 27, 2010
Just bought the machine. Basically, the problem is that the steam wand goes of on its own (or as soon as I push the coffee button) and that I cannot turn the steam handle at all or do anything to stop...
Hi. Make sure all your buttons are off. (switches all facing the same direction). Then make sure the tap is turned off. Switch main power on. Then switch the coffee on. you should hear the pump start. usually loud at 1st, then it will get quiter as the water is pumped up through the group head. When water is pouring through the group head, switch off the coffee button. Now let it finish heating. If you can get to this stage, then everything is ok. If you cant get it to this stage then you have a problem with the machine. Most likely a themostat on the boiler. Darryn REPAIRER
Sep 22, 2011 | Rancilio Silvia Espresso Machine
Jan 26, 2010 | Rancilio Silvia Espresso Machine
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia indicator light not turning off
Hi
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also another problem that you might have. If the brew thermostat is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
If none of these things work check the heating element with an ohms meter. The reading in the terminals should be from 12 to 16 ohms. If no reading the elements is bad and you have to replace the boiler.
Hi - I have a new Rancilio that I just opened today. Steam is coming but not enough water for a brew
maybe is just air in pump,try prime water on steam wand.open steam valve and press button for make espresso,keep couple seconds
Jul 07, 2009 | Rancilio Silvia Espresso Machine
Not heating up the water
Hi
3 things could be wrong. First is easy to check. With machine on, turn on the steam switch and after about a minut open the steam knob and push the middle switch. Check the water coming from the wand and see if its warm? If it is you need a brew thermostat. Unplug the machine. Remove the water tank. Remove the 4 screws that hold the top on and lift top off. The boiler has 2 thermostats on the top front of the boiler, and the one with the red dot is the brew thermostat and need replacing.
If that didn't fix your problem there is a reset thermostat on the front face of the boiler and has black wires going to it. There is a red button in the middle of the thermostat and needs to be pushed.
If that one didn't solve your problem you need a new heating element. You can do a continuity check on the terminals.
Apr 20, 2009 | Rancilio Silvia Espresso Machine
Water will not come through the steam wand
Dec 07, 2008 | Rancilio Silvia Espresso Machine
No water ever makes it through the pump
You have to prime the pump.. Hit the water button and open the steam knob.
If no water goes through the steam wand I would check for a clogged water line.
Ranclio parts and Espresso Machine information
www.CeriniCoffee.com
Nov 19, 2007 | Rancilio Silvia Espresso Machine
Coffee Makers & Espresso Machines Logo
164 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
Marvin
Marvin
markybean
Level 1 Expert
ray gallant
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
