Question about LG Washing Machines
LG front loader WM 3470 HWA: left sprayer not working
Posted by Janith Mason on
robert
  • LG Master
  • 2,535 Answers
Could be the water valve
Posted on Jul 22, 2019
5 Related Answers
Anonymous
  • 210 Answers
SOURCE: LG Front-Load Washer WM2277HW ce sign
CE is an error stating that you have a problem with you board or possibly the stator on your unit. Either way your going to need service. You can ohm out your stator to see if it is the problem.
Check the back harness, maybe it has come loose, remove the back panel and it is the blue connector.
Sgt 48
Posted on Jun 08, 2008
Anonymous
  • 210 Answers
SOURCE: LG WM-2277HW Front Load Washer not working with ce showing
Sgt 48
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: LG WM-2032HW front loader
"OE" is really "DE"= drain error. Clean out filter behind access door on lower left corner front panel of machine. (there will be some water in machine)
"IE" = inlet error. machine took too long to fill. clean out inlet water screens where the hoses connect onto machine.
Posted on Oct 02, 2008
Anonymous
  • 12 Answers
SOURCE: LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Posted on Oct 24, 2009
Anonymous
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
Lg front loader washer WM 0532HW doesn't spray water anymore
u could try running a cycle or two with a mixture of 1 part vinagar to 3 parts water and see if it cleans out use hot water
Feb 26, 2013 | LG WM-0532HW Front Load Washer
Why does my lg front loader washer wm-1832cw sometimes give anle code and sometimes works
you have either a hall senser /stator/or main board/problem.... may even be a voltage issue. check your recepticle see if its good. easy first check plug to see if its been arking on the plungs
Jun 03, 2011 | LG WM-1832C Front Load Washer
What does a pump filter consist of on a front loader tromm
Get some towels ready for the floor'
Open the small door on the left side bottom
Unscrew the large black cap pull out and clean filter
Jul 02, 2010 | LG WM-2277HW Front Load Washer
Lg tromm front loader washer wm0532hw shows oe error
that's draining error. check the filter cleanout behind lower left panel on front of machine; of course drain 1st via small drain hose. if thats o.k the drain pump itself may be jammed with debris or the drain hose could be clogged.
Jun 24, 2010 | LG WM-2277HW Front Load Washer
LG Washer front loader stopped mid wash and is lock can't open door
unplug/plug unit. drain water via hose behind lower left panel on front.
Jun 03, 2009 | LG WM-0532HW Front Load Washer
LG WM-2032HW front loader washer gives error goes OE and IE
Oct 02, 2008 | LG Washing Machines
Washing Machines Logo
42 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
