Question about The Watches
Will the AX5535 watch band fit the AX5311 Olivia watch?
Posted by Kathy Gill on
Ngoro
    Top Expert:
  • The Master
  • 2,647 Answers
Armani AX5535 : Band Width 18 mm
Armani AX5311 : Band Width 16 mm
https://www.watch.co.uk/watch-straps/armani-exchange/?strapsearch=ax5535
https://www.watch.co.uk/watch-straps/armani-exchange/?strapsearch=ax5311
Posted on Jul 22, 2019
3 Related Answers
Anonymous
SOURCE: watch link
HOW DO I TAKER A LINK OUT OF THE WATCH BAND
THE MAHE UIS KENNITH COLE REACTION KC3555 P93-07
Posted on Aug 11, 2008
news775
Robin Bonathan
  • 699 Answers
SOURCE: Had rubber band fitted, instead of metal band,
ebay is your friend, look there and you should find one.
Please dont forget to vote this answer was helpful.
Many thanks
Posted on Mar 04, 2011
small6363
  • 18429 Answers
SOURCE: sportline watch #4823 band broke, need replacement, where?
try this link below
http://www.sportline.com/contact-us/contact-info.html
Posted on Oct 07, 2012
HOW OR WHERE TO GET A NEW BAND FOR ANNE KLEIN WATCH 10/9442?
that is a pretty funky fitting! However, that is a plain leather band that is screwed to the fitting. Your local jeweler could do that job for you or contact them direct. You will get a plain strap with two holes in it.
Anne Klein Women 10 9442 Leather Strap Watch
eBay have some
Anne Klein Watch Bands eBay
Jun 30, 2018 | Anne Klein Watches
Will bands for my current Apple Watch fit the new Series 2 model?
yes it will as long as its the same size watch face
Sep 09, 2016 | Apple Watch Series 2
How can I change the wrist of my new apple watch?
I guess that you can buy them on-line or in apple store but you can definitely change them, this is what apple say in their website: A different band can really change the look of Apple Watch. So we created a full range of them in a variety of materials. The grooves in each case are precision engineered and CNC machined to ensure a perfect fit with any band. And beautifully designed buckles and closures provide the perfect finishing touch.
Apr 16, 2015 | Apple Watch
Broken band, how can I get new rubber band? where??
It looks like that may be a custom band, this site has some great bands, http://www.watch-band-center.com/shop-watchstrap.html?gclid=CjgKEAjwoJ-dBRDbjfKN7IzN0FsSJAAP0G_DR8AwTfhcxt7HHIHONLoaf1QZfq7YeqCB6Vt1_oZKV_D_BwE
you'll need to measure how wide your band is where it connects to the watch to ensure you get the correct fit.
Jun 24, 2014 | Ducati Cw0025 Desmo Watch for Men
Need to replace my leather watch band on my goofy watch with an authentic disney band. it is leather with no characters on the band & underside is stamped with disney made in china. Need size &...
If you need an authentic Disney watch band, try asking at a Disney store. However, non-Disney watch bands will fit this watch and may be both better quality and less expensive. Almost any jewelry store, department/discount store jewelry counter, or shopping mall watch kiosk will be able to measure your watch and determine the right size band. Many women's watches in this general style use a 14mm or 16mm band, but you should measure your watch to make certain.
May 05, 2011 | Disney Goofy Brown Leather Strap #D075S007...
How do you put the back, back onto this fs1? The band keeps getting in the way! Back came off easily enough, popped off after unscrewed. Band is still on watch, have tried to slide back into grooves but...
You have to remove band in order to fit caseback back onto the watch. Insert pocket knife blade between band and case lug and pry inwards. This motion should release the band. It will be a lot more difficult to fit the band back on and you will probably need to buy springbar tool. Rate me plz.
Mar 03, 2010 | Polar FS1 Unisex Heart Rate Monitor Watch
Replacing watch band on pathfinder pas410. can't get pins out to replace band.
Watchmakers use special tool to release spring bars, but it is possible to release them in home conditions. Place your watch on flat surface face down. Using pocket knife insert the blade between band and the watch lug where the spring bar (pin) end is and using lever action push spring bar end inwards. This should release the band from the watch. If all this does not work, then your watch band is attached with friction fitted pins and you will need watchmakers help, as without special pin removing tool it is not possible to remove friction fitted pins.
Rate me, plz.
Jan 08, 2010 | Casio Pathfinder PAS410B5V Wrist Watch
Need new watch band for tag heuer watch the one i have is too small. how much is it to replace a watchand
TAG HEUER watch bands are costly. Over here in England they cost from £60 to £250 (depends on type, model, e.t.c.), but can rocket sky high if you have one of expensive models.
I would suggest to add a few links to your existing band. This will be cheaper than to buy completely new band.
Visit your nearest watch repair store and ask how to do that. Watchmaker should be able to order extra links and fit them for you.
If you insist on a new band - ask watchmaker to order it and fit to your watch.
Rate me, please.
Aug 13, 2009 | Samsung Watches
Watches Logo
136 people viewed this question
Top The Watches Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
gbob59
Are you a The Watch Expert? Answer questions, earn points and help others
