Question about Refrigerators
THE LIGHT ON THE ICE AND WATER KEEP FLASHING - Refrigerators
Posted by CAROLYN WEISEMAN on
Red light flashing i push tab on the left hand side light stop flashing ice in the maker but dont fall
If the ice has not been used for some time it becomes frozen solid, defrost it and all should be ok.
Apr 18, 2016 | Maytag 25.6 Cu. Ft. Side-by-Side...
I have GE Monogram Side by Side. Purchased back in August 2006. It has been pretty good except for the ice maker. After the first year a leak ruined our new wood floors. Recently the ice maker has...
The green light flashing is a fault code, usually for a no, or long fill situation, GE has nixed this electronic ice maker and returned to one that looks similar but is non electronic, while your ice maker is probably at fault you may actually have a separate issue causing the ice maker to display a fault code, such as a spent water filter, or low water pressure, or even a bad water valve on the fridge it's self. IM6 is the current replacement ice maker kit for previous ice makers. Pleazer Appliance...
Apr 17, 2014 | GE Monogram Side by Side Refrigerator
Green "ice size" light is
try to reset your unit to unplug the unit then after a several minutes plug it on then observe the unit.
Mar 06, 2011 | Refrigerators
Kennmore refrigerator is not making ice,but water
The control light flashes to indicate the infrared beam is being blocked. The flap on the opposite side blocks the beam when the door is open to prevent ice from being dropped on the floor rather than in the ice bin. If you pushe the flap in so it's flush with the liner (use care not to block the hole) the light should go from flashing to on in a steady state. If not, your electronics are bad and would need to be replaced. If the light does glow steady, then the problem is with your ice maker, water valve or ice maker fill tube.
Dec 23, 2009 | Refrigerators
Ice maker is not making ice, yet the red light that indicates the ice maker is "ON" is flashing..
KitchenAid KSGR25FTSSOO side by side one day just quit making ice. We have blown out the lines and replaced the filter. The red light does blick when we open the door. The water despenser as a flow of water that is real slow. How and what do we do next?
Oct 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker does not make ice. water will dispense thru door and I replace the water filter every six months.
I had the same problem. There is air in the line therefore you need to dispense about 3 gallons of water from the dispenser and that should slove the problem. Also, take a clean soft cloth or paper iowel and wipe the ice make sensor (if you have one) and the reciever. There is one on each side of slightly below the ice maker. Should be a flashing or steady red light ....follow the flashing red light to the other side.
Oct 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The ice maker is not making ice
I assume "light flashing [email protected] switch" means the inside light turns on when you open the door, and goes off when you close the door, or depress the switch manually.
Sounds like the fill valve has failed at the bottom back of the refrigerator.
Reply back your findings if that is not it and I will give you more suggestions.
Jan 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker Not making Ice
Water is in the tray and you have freezing temps? Can you tell me a little more? The flashing red light began when the ice tray filled and did not freeze? Let me know when possible, Thanks JT
Oct 23, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
