Question about Sony Computers & Internet
SOURCE: monitor shows no signal
ur monitor is "not" the problem... you have problem in ur PC..
solutions:
check loose graphic card
remove ram. put them back again/...
Posted on Feb 11, 2008
SOURCE: 5 red flashs on power/standby light on kdsr60xbr1 screen blank,
Thats the error for lamp driver error. Which means the Ballast is most likely defective. You can get the replacement ballast for your model at the following link which comes with installation instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/kdfe42a10-ballast-assembly/cName/sony-parts
Posted on May 23, 2009
It sounds like it is loseing signal, check your connections, and make sure you have the correct cable
Posted on Jun 01, 2009
SOURCE: washer will not restart cycle after a brief pause to add an item.
inspect the door latch assembly . you should see a plunger or switch that goes in and out as door shuts also should be a plastic stem that is mounted on the door that slides in and out of the latch assembly on the door
Posted on Aug 08, 2009
SOURCE: I have 3 att uverse cable boxes...1 being the dvr
Unplug the power from the DVR wait 5 secs plug it back in
Posted on Dec 19, 2009
Hi Leslie Yandle, I want to help you with your question, but I need more information from you.
Please Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7/
