Question about LG Washing Machines
Damage to fabrics due to baffles Does anyone has a solution to prevent damage during spin cycles other than removing the baffles?
Our LG washer severely damages the fabrics. New shirts, towels and bathmats are torn and / or have holes after a single wash. We have the machine less than a year. It is still under warranty. The total damage to clothing and fabrics is already more than the purchase price of the washer. It appears to be related to spin speed, but even at medium spin speed some damage occurs although less frequently. Damage is likely caused by the stress of the fabrics draped over the rather high and steep baffles during spinning. A very poor design and apparently not tested! I expect that the degree of damage depends how the fabric is distributed over the drum. If (say) a shirt is hanging over a baffle, there is enormous stress on the fabric at high spin speeds and it may tear. If the shirt ends up falling in its entirety between two baffles, there is hardly any stress in the plane of the fabric (and no damage). At low spin speeds the laundry is rather wet and that is therefore not an attractive solution.
Posted by Veer on
Tom Chichester
    Top Expert:
  • LG Master
  • 57,309 Answers
You can try having the machine repaired or replaced under warranty but the real problem probably is poor design.
Posted on Dec 19, 2019
5 Related Answers
Junoon007
Asfiya Ahamed
  • 1011 Answers
SOURCE: Admiral Washing Machine (Model LNC6760B71)- clothes remain damp
Sir,
The motor on this washer turn one way to wash and the other way to spin and drain.
So if the washer is spinning and not draining you have a pump problem.Take the front panel off and watch to see what is happening.
You will have to check for power to the motor in spin. Either the motor is bad or the timer or both. Refer to the schematic for this.
Thanks
Good luck
Don't forget to rate the solution
Posted on Jul 25, 2008
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: Roper washer ras7133kq1will not spin enough to wring out clothes
bad motor most likely. easy fix
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 05, 2009
fixer444
  • 106 Answers
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Posted on Mar 02, 2009
beltronic205
Gerry Harvey
  • 1481 Answers
SOURCE: Clothes are still very wet after the spin cycle.
sounds like not pumping very well, try cleaning the filter/ pump
Posted on Apr 20, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Automatic Washer model no. 110.23032100 Slow spin speed
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
I am getting black streaks on clothes after washing.
Make sure the washer is level, especially front to back. Do not overload washer. Check to see if marks are coming from build up of gunk in the outer bowl.
Apr 09, 2015 | LG WM2301H Washer
I have a brand new maytag 4000 series front loader washer that shakes across the floor while on spin cycle. it is level and balanced. not sure what is goin on.
This sounds like the transportation support rods have not been removed. A new machine will have two or more steel rods supporting the drum to prevent damage during transportation. These rods MUST be removed before the machine is used, otherwise the dampers that prevent excessive vibration will not be effective.
The user manual should provide instruictions for removal of the rods. They are normally accessed from the rear of the machine and usually will be labelled so that it is clear how to remove them. They pass througn the chassis of the machine and should be unscrewd and pulled out from the rear.
Jan 22, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Code LE, will not finish the spin cycle
It's very important not only to use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect dosage instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Apr 01, 2010 | LG WM-2277HW Front Load Washer
A feather pillow busted during the cycle - What do I need to do to prevent damage?
either you have overloaded the machine or else your spin speed was set on high, lower it down and it should not happen next time.Make sure there is nothing broken inside the tumble or the spinning area...
Jan 14, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Violent spin cycle on the Frigidare front-loading washer
I assume you bought it new, so on that basis, did you remove the transit packing materials inside the machine ?
Front loading washing machine normal design is for the drum assembly to be supported by two or more springs at the top, and two dampers at the bottom. This allows the drum to move in a controlled fashion and also minimises vibration, particularly during spinning.
When the machines are shipped from the factory, transit packaging is put inside the machine to ensure that any shocks to the machine during transit dont damage the springs or dampers. This must be removed before use otherwise you get pretty much the symptoms you describe.
The manual that cam with it will show you how to remove the transit packaging. In such a short time I suspect you wont have suffered any damage, but take the transit packaging out as soon as possible.
Nov 04, 2009 | Frigidaire ATF6000ES Front Load Washer
Bosch NEXXT 500 SERIES washer Makes knocking sound while spinning
during transport there are fittings installed to prevent damage to the machine. The shaft may have got bent but before panic sets in try to check 1. that there is a gap between the mahine and units
2. that the unit is leveled.
Aug 16, 2009 | Bosch Classixx WFC 2465 Front Load Washer
The spin cycle for my
Dear shelldon39, Fri 2-20-2009 9:24pm EST (USA)
Some machines will shut down during the spin cycle as a precaution to prevent damage!
They will do this if you overload the washer with clothes and/or use too much detergent!
If this doesn't help please get back to me with more details!
jack
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 13, 2008 | LG WM2688HWM TROMM SteamWasher
Washed clothes while on the 'clean washer' setting
I'm sure that the exact make up of clean washer or tub clean cycles vary from brand to brand, but basically that cycle fills to a higher water level, hottest water, and highest spin, turning off load sensors / out of balance sensors so the machine can spin with water in the tub (allowing tub cleaning agents to contact all tub surfaces). (all other cycles pump the water out before spinning) Having a load of clothes in the machine at this time could result in overloading machine (gererally causing an error code), damage to suspension components, damage to hoses or connections resulting in water leaks, etc. Due to the large water level, your clothes would be agitated more ****, but the hot water might damage some fabrics. A FixYa rating would be appreciated for this info. Thanks.
Nov 13, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Maytag Epic Washer high spin shaking, AND high-pitched sound coming out of washer
When someone reports severe vibration during spin on a brand new washer, the first question always has to be whether the transit brackets have been left in.
Washers are designed so that the drum and motor float on a collection of springs and shock absorbers. To prevent damage to these during shipping, a set of brackets is used to bolt the floating assembly to the case. If these aren't removed before first use (the manual will say how to do it) havoc ensues.
The irritating whine is a new one on me.
A.
Jul 04, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
1,020 people viewed this question
Top LG Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
