Can computer be used via vga on tv - Televison & Video
Posted by peter yates on
1 Related Answer
Anonymous
  • 2600 Answers
SOURCE: Have Sony VAIO VGN
You may have to manually toggle the video output of the laptop to the external video circuit. This isually done using the Fn + F7 key combination. This toggles the display from the integrated lcd to the external to both to just the external etc.
Posted on Jan 19, 2010
How do I change source resolution on my TV?
connecting PC to Tv through VGA - Tom's Guide
www.tomsguide.com/answers/id-1891563/connecting-vga.html
Nov 20, 2013 - Q: Can I connect the TV to the PC via a VGA cable...bearing in mind the .... Forum; SolvedI'm trying to connect my Sony bluray player home ...
Connecting my Plasma to my PC via the VGA port. - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Ensure that the VGA cable is working properly using other methods. Perhaps .... I am trying to connect my pc with my samsung tv. .... I'm very sorry to hear that has happened, and I apologize for any inconvenience this may have caused you. Connection between Dell laptop and Samsung TV
Jun 11, 2015
How to connect computer to tv with sound and picture?
Jun 5, 2015
PC Audio won't play through connected Samsung LCD TV
Jun 4, 2015
Connecting computer to TV
Jan 18, 2008
More results from www.cnet.com
My custom built PC will not connect to my TV via VGA cable ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Jun 28, 2013 - 5 posts - ‎2 authors
Jan 31, 2016 | VIA Computers & Internet
How do I hook my HP Pavilion Notebook up to this television?
You can connect via HDMI > HDMI if both have one, or VGA to VGA, VGA > HDMI all leads available on eBay. go to source and choose VGA option.
May 17, 2015 | Sansui 19 in. LCD TV
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
My pc wont recognise my tv as a second monitor - conected with VGA cable
the video card you used have a capability for dual monitor..so 1st thing that you need to do is to make sure that the computer recognized the 2nd monitor and activate dual monitor capability on the nvidia panel..after that on your tv select the proper source(like VGA, HDMI1 etc.) on which you'll be able to see the the video from the computer to your TV..
Jan 31, 2012 | Dell Computers & Internet
I Want to Play TV programs Through laptop to TV
Most late model TV can be use as a Computer monitor either via a Computer VGA input of via a HDMA input (providing your laptop has HDMA support and output). You will need the appropriate VGA or HDMA cable to connect your Laptop to your TV acting as a monitor.
Sep 24, 2011 | Televison & Video
How can i use my tv as a computer monitor?
Most newer televisions come with a VGA connection on the back which is the same as for any normal computer monitor. If your tv has this just connect via the vga lead and then select the valid port on your tv. If you wish to use sound as well then as audio lead must be used from the speaker output to the red and white audio inputs on the tv.
If you don't have a vga port on the tv then you maybe able to get an interface that will go convert to something that will plug in to your tv.
I hope this helps.
Jun 20, 2011 | Computers & Internet
I want to connect my Sony Vaio VGN-NR120E to my TV Samsung. But I have no idea how to do that. Could you give me advice ...
Your Sony vaio does not have any TV-out port to output the display on any analog TV. You can use your VGA (by using VGA cable) port to output your laptop on LCD / Plasma / LED TV (with a VGA port also)). If you still want to project to analog TV via the VGA port, you need to find a VGA to RGB adaptor. But bare in mind, it's hard to find one.
VGA port is like the port on computer monitor. RBG consist of three colored port.
Good luck ;)
Mar 09, 2011 | Sony VAIO VGN-NR120E/S Notebook
I have connected my PC to Panasonic TH-L24C20D, I want audio output via TV speakers. what to do?
If your computer has an HDMI output, the audio is already connected to the TV in digital format via its' HDMI input. However, if you are using the VGA from the computer, you will need a separate audio system to output the audio from your computer. The VGA is an analog video only. Your TV does not have an audio input so therefore you need a speaker system from the computer.
Dec 20, 2010 | Panasonic Televison & Video
Can i connect my laptop to the tv?
Yes there is a way to connect the laptop to the TV via VGA output. You can easily connect most of the laptops to TV via VGA and your notebook is fine for that purpose as well.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 07, 2009 | Toshiba Satellite L305-S5933 Notebook
How to switch from Computer to TV if the PC is connected via D-sub and Set top box via HDMI port
Most LCD displays have an input select button to choose the TV ot PC display. You just press the button and it cycles thru the options. Normally starting with VGA, then DVI and then the remaining input options.
Jun 19, 2008 | Computers & Internet
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
