How to use this machine. I can’t figure out how it opens, help!
Posted by Joan McKenna on
Andrew Taylor
    Top Expert:
  • Washing Mach... Master
  • 33,101 Answers
'this machine', the secret one that only you know :>b
Google
make model manual
they are all online.
Top loaders have a lock which is strong. Some front loaders have a press button on the door or on the panel.
Posted on Jul 21, 2019
The dispenser drawer on my AEG Lavamat is stuck half open and appears jammed. Help please
Open the machine up on the top lid. 2 screws at the back of the machine at the top. Slide the lid back and remove it. The drawer can now be accessed. There should be a bunch of clips holding the lid of the drawer . You can carefully open these clips to remove the lid or just remove the entire drawer assembly and replace it or try to figure out what is jamming it.
Jan 22, 2018 | AEG Washing Machines
Jura capresso c3000 yellow clip
I found out where it goes, thanks to Juergen, who pointed me toward his excellent page on Jura cleaning: see figure 7d, copied here
which shows the yellow clip helping to hold on the tea pipe. I'm guessing that if you don't use the tea pipe, you will be okay. Otherwise you can just put that clip back on next time you clean the machine.
Nov 08, 2012 | Jura Capresso C3000 Espresso & Coffee...
I have to get a letter typed and don't know how to open the machine to change the ink????
  1. Open the cartridge access door. Figure 4: Open the cartridge access doorc00127636.gif
  2. Raise the cartridge latches for both cartridges. Figure 5: Raise cartridge latchesc00127637.gif
  3. Remove the protective tape from the end of the cartridges. Figure 6: Remove tapec00127639.gif
  4. Insert the cartridges into the carriage. Figure 7: Insert cartridgec00127642.gif
  5. Close the latches, and then close the cartridge access door. Figure 8: Close latchc00127644.gif The control panel displays a message prompting you to align the cartridges.
  6. Press the Enter button to start the cartridge alignment. Wait until the alignment completes before continuing.
Jun 24, 2011 | HP PSC 750 All-In-One InkJet Printer
I dumped everything off computer and still cant get futura ce100 to open did what singer said several times still won't open and machine is on. Please help running vista.
Make sure your USB cable is plugged into one of the USB ports on the BACK of your computer. The front ports or a USB hub doesn't have enough power to run the USB cable for the machine. Singer doesn't have enough computer knowledge to figure this out-this was finally solved for me by a PC expert at work after I went nuts for a few months! Hope this helps!
Jan 13, 2011 | Singer CE-100 Futura Computerized Sewing...
THE RED LIGHT ON MY DIAL IS STAYING ON. AND I DON'T KNOW WHY OR WHAT THIS MEANS. CAN YOU HELP
I have the same problem. I don't know how to fix yet, but the cause is from opening the lid while the unit is running w/o stopping the machine b4 opening! As soon as I figure how to get it to turn off I'll repost
Nov 09, 2009 | Braun Tassimo Espresso Machine/Coffee...
LG Tromm Front door won't unlock
I have this exact problem!!! Did anyone ever figure it out??!! HELP!!
Jul 27, 2009 | LG Washing Machines
How to use white cams
hi! there,
white cam plate are mounted on top side of your machine there
is shaft for mounting on figure the plate cover opening for cam,then adjust the dial for the neccessary cam designed.32e83f9.jpg
you have to replace the presser foot on figures.5af54f1.jpg this presser foot is more convenient to use on designed cam
the stitch adjustment should # 8 to # 12 just select w/c more convenient to yuo,dial tension set to # 3 to # 6.
have a nice day,don't forget to rate me,thank's
Apr 26, 2009 | Kenmore Sewing Machines
Adding machine problems
how do I clean the printer roller on a Texas Instrument TI-5130 adding machine?
Apr 24, 2008 | Office Equipment & Supplies
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
