Question about Electrical Supplies
Where is the fuse at on the 8750 watt portable generator
Posted by Craig Heimbach on
Generator Guru Parts
    Master:
  • Electrical S... Master
  • 269 Answers
We hold parts for your Generator and have a whole Help Center dedicated to helping people fix their Portable Generators. If the answer is not there, we have Generator Engineers who can help. Check it out on our site. https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
where is the fuse at on the 8750 watt portable gen - image-2fwsrbehqcya13uxwt41l5dc-5-0_1.jpg
Posted on Aug 19, 2019
5 Related Answers
Anonymous
SOURCE: Coleman Powermate 8750 will not generate electricity.
my name is scott i work on generators,i realy need more info so ill give u some basics
................1] need to check your brushes u can get to this on the back side of the motor,by tacking out the 4 bolts or depending on the cover a 1"x3" plate
................2]if that is good then i would test out the field or armature
p.s. all of this is done on the motor not the engine, also u may also want to talk to tech support at PRAMAC,this is the suplier for coleman/powermate
Posted on Mar 04, 2009
mamicheddy
mamicheddy
  • 79 Answers
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
motor1258
Mike Butler
  • 6674 Answers
SOURCE: portable generator pops breaker when temp is over 75 degrees
I take it you have RV plugged into generator. Hopefully direct with no extension cords. Are you using a 30 to 15 amp adapter to plug into generator? What is the rating of the breaker on the generator that keeps tripping, suspect it's only 15 amp?
Posted on Jul 20, 2009
Anonymous
  • 142 Answers
SOURCE: use a 7500 watt transfer switch with a 8000 watt
There is no problem to use it if the load to be transferred is under 7500 W.
Even a load of 8000 W may be handled for a short time, but if the protection of the switch is adjusted at 7500 W (the respective current), it may drop after some time.
Posted on Aug 07, 2010
ImJustAvg
  • 2006 Answers
SOURCE: Guardian 15000 Watt Portable Generator
Suggest you go to Amazon.com and do a search for the Generac Guardian. When you find it, look in the product details and you will see Product Manual (PDF) under the Product Details.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000031765.pdf
it has a troubleshooting guide located on page 19.
No Battery Charge DC output.
1. Battery posts are corroded. 1. Clean battery posts.
2. Battery cable is bad. 2. Replace cable.
3. Battery is defective. 3. Check battery condition; replace if
defective.
4. Receptacle is bad. 4. Contact Authorized Service Facility.
Hope this helps!
Posted on Jun 02, 2011
Free manual 7000/8750 black max manual
Try Googling (Honda)(BM907000)(manual) without parens.
May 06, 2017 | Honda Black Max 7000 / 8750 Watt Portable...
My Powermate 8750 does not put out electricity! I checked the brushes seem ok? Tried flashing it at the brushes but not even a spark?
If the motor runs AND there is no electricity the power regulator modul can be damaged by faultering slide contacts or overload, if there is no circuit breaker protection is to find, a power assembly if there is used or a capacitor damaged.
Oct 06, 2016 | Powermate 8750 Watt Portable Generator...
Having trouble getting my BlackMax 7000 watt trifuel generator started on Propane.
Clean off the fuel connect points. Probably just not a clean line from sitting so long since last use.
Dec 25, 2014 | Honda Black Max 7000 / 8750 Watt Portable...
Need help with diagnosing generator not producing power
may be a bad breaker or a shorted wiring problem. not generating any power, I would ck. the brushes inside the generator.
May 19, 2013 | Briggs & Stratton Power Products 5,550...
Cant get my power ate 8750 to start. Ran fine last year. Have changed spark plug, aded fuel stabilizer, will starting ether help?
My son in law drained the carborator 3 times to get the old gas out. Also put in an additive to the gas. He figured our unit had sat too long and the gas was getting old. It is running fine now. Just need to figure out how to idle it down.
Oct 28, 2012 | Coleman Powermate 7,000 Watt 13 Hp...
I need a battery for a predator portable generator
Go to WalMart and look at their EverStart line of batteries for motorcycles and ATV's. I have the 8750/7000 watt predator and the EverStart ES9BS works great and fits well on the holder. It comes with the acid and you will need to add the acid and fully charge the battery before use.;
Jul 27, 2012 | Electrical Supplies
Do i mix oil in the gas on the coleman powermate 8750 honda 13 hp?
Hi, no you don't. It is a four stroke engine and uses engine oil in the sump only. Regards Phil.
Jul 28, 2011 | Coleman Powermate 7,000 Watt 13 Hp...
Electrical Supplies Logo
140 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
