Question about Mitsubishi Televison & Video
Old mitsubishi tv,takes several tries to get power light to stay on
Tom Chichester
    Top Expert:
  • Mitsubishi Master
  • 55,379 Answers
Failing power supply
Posted on Jul 21, 2019
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: green power on light flickers
You may need to repair the DM board, do you have any solid state repair experience? Check this out, it is already posted here! http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Good Luck to you!
Posted on Jul 30, 2007
Anonymous
  • 35 Answers
SOURCE: Tv won't stay on
i have seen this before and it may be the front power button being stuck and when your remote turns it on the stuck button turns it back off again. I have an older mitsubishi that will not boot up right sometimes and i have to unplug it and plug it back in fot it to come on. I used to pick up broken tv and fix the power buton and resell them
Posted on Mar 27, 2008
Anonymous
SOURCE: TV power will not stay on.
mine was the 904 and 905 pico fuses in the power board. $4.00 is what the fuses cost me. I put them in myself and have never worked on a tv before....
Posted on Dec 31, 2008
Anonymous
  • 556 Answers
SOURCE: Mitsubishi WD-Y57. tv tries to start green light - no picture
have you checked the lamp?
Posted on Aug 14, 2009
Anonymous
  • 21 Answers
SOURCE: Mitsubishi Diamond TV power went out TV wont turn back on.
the regular problem is the convergence kit,
Posted on Jan 20, 2010
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Timer light continues flashing; won't turn on/off
Could be an open internal fuse or power supply failure
Jun 25, 2017 | Mitsubishi WD-65731 65" HDTV
My television is cutting off and takes forever to restart. the green light stays on. I have tried to reset the tv. same ol thing. replaced the lamp its not that. a big blue screen pops up before shutting...
Hello! If you haven't replaced the lamp before, I recommend you do it, since it's already 4 years old. If you already replaced it, there is a possibility you might be having a ballast issue. The ballast is the board in charge of sending all the power to the lamp so it can light up. www.discount-merchant.com/?Click=48427 These part are not that expensive and will get your TV up and running.
Nov 18, 2009 | Mitsubishi WD-62725 62" Rear Projection...
The lamp light is still on after replacing the
Plug the TV out of the wall. Wait. Plug it back in. Does it still stay on? If not, there is somethign wrong with your remote, or the TV circutiry is not shutting off. Try controlling the on/off via manually pushing the power button on the tv (both on and off).
Jul 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a 4 month old Model WD-73736 tv that is nonresponsive
i'd take it back!  it's obviously defective.  TV's are supposed to last longer than 4 months!
Mar 27, 2009 | Mitsubishi WD-73736 Television
Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Tv won't stay on
Mar 27, 2008 | Televison & Video
Red Status Light
Hi we have a 52 inch mitsubishi high definition tv and ours did the same thing,we had a repair man out here and he said it was the engine in the tv which we never knew tv's had engines so i contacted mitsubishi cause we didn't take a entended warranty and told them that it was not even 3 yrs old and they should stand up to there products and they did they paid for the part which was 600 dollars and we had to pay for labor....we thought it was the light to and ordered one and it wasn't it was doing the same thing yours did .....
Jan 13, 2008 | Mitsubishi WD-65731 65" HDTV
Televison & Video Logo
157 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
