Question about Fisher Paykel EcoSmart GWL15
Fisher paykel washer has on occassion left grease on clothes
Fisher paykel washer has on occassion left grease marks on clothes. Any suggestions. Today I believe I had put to many towels in the machine and put it off balance. it stopped mid cycle and all the towels had black marks on them. I was able to put in sink and get most of this off but just wondering what is going on here. the machine is 5 years old.
Posted by steve569 on
keith jones
    Master:
  • Fisher Master
  • 747 Answers
It is unlikely its coming from the machine rather some you put in there,try a short hot wash with strong detergent,no clothes
Posted on Sep 03, 2018
3 Related Answers
Anonymous
SOURCE: hi I have a gw
Try to unplug the washer and leave it off for a minute. Replug it and see if it will run. Otherwise, check your circuit breaker.
Posted on Jan 02, 2009
Anonymous
  • 15 Answers
SOURCE: I am getting grey marks on my light colored
THE PROBLEM IS THE AMOUNT OF DETERGENT YOU ARE USING.YOU NEED TO BE USING HE OR HIGH EFFECIENT DETERGENT. THIS MACHINE USES MUCH LESS WATER THAN YOUR VERAGE TOP LOADER.
Posted on Apr 07, 2009
victor-app
  • 14 Answers
SOURCE: fisher and paykel washing machine stopped
If the light that stays on when beeping is 7th from the right then the machine has a pressure transducer which is out of range, the motor controller module (electronic) will need to be replaced.
Posted on Apr 22, 2010
1helpful
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
1helpful
Fisher Paykell washer left black grease spots on some clothes
9 WASH PERFORMANCE INFORMATION
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
9.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature
according to soil type. For example, blood and mud are better washed in cold water, while sweat
and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will
wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent
than soft water.
9.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the
instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
9.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
9.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that the machine be periodically filled with hot water, plus
detergent and left to soak.
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
9.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load the machine by wrapping clothes around the agitator.
There is black stuff down under where u put the washing softener and it is getting through the washing!
Put a cup of malt vinegar through a whole wash cycle (without clothes in it). Cuts all the grease away from throughout the machine.
2answers
My washer leaves black marks on my clothes. I do not use fabric softners
Do you mean Black, really black marks? Perhaps dark brown.
Some marks comes from moldy seals, other marks comes from leaking gears from the machine. Examine the marks, check if those marks are oily or not.
2answers
Dirt left in creases after washing clothes. Clothes never look clean
Too many clothes in the load , if it says 5lb then that is the maximum you should fill it with otherwise the clothes do not seperate as they are being agitated
Also
Not enough detergent (Try the old powder types)
Hard Water area (Use a small amount of Washing Soda)
Water level too low , use add water button if fitted
I am getting grey marks on my light colored clothing. I have a Fisher & Paykel topload washer.
2answers
Fisher and Paykel top loading washer
This is not grease this is a build up of poweder in the machine on the outer bowl, this will also happen if you use too much fabric softner. :)
Sounds like you could need a new out of balance switch or bracket, also try to make the clothes evenly spread in washing machine on rinse if they clump up on one side of the bowl they will cause out of balance :)
Intuitive Eco
Would suggest doing a full hot empty load, using bleach according to bottle instructions. It sounds like a build up of scum from washing powder, fibre from clothing etc. Can also be caused by overuse of fabric conditioner.
2answers
Getting inside the Fisher-Paykel GWL15 washer
thats it , remove those 2 screws and the top will flip back, the new "clothes guard"( neck ring), will snap right into place, be sure to rehook the spring to hte left front susension rod!
Fisher Paykel EcoSmart GWL15 Logo
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
