Question about Generac Electrical Supplies
I have Generac GP8000E (G0069310) and the engine runs great but generates only 2-3 volts.
This is a BRUSHED EXCITATION generator with a voltage regulator. When I received the generator the voltage regulator was missing, so I replaced it. I get 2-3 volts when using a meter directly connected to the voltage regulator or alternator. The fuses on both the GFCI outlets will not reset. The 208-volt outlet has 2-3 volts. Do I need to flash the generator? If so how do you flash a brushed generator? Thanks.
Posted by Matt Johnson on
  • Matt Johnson
    Matt Johnson Aug 19, 2019
    I already replaced the AVR. No change. Thanks for the advice though.
Generator Guru Parts
    Master:
  • 269 Answers
Most of the time it is the AVR that has blown. Check out our videos on how to test them.
We hold your AVR in stock and have a whole Help Center dedicated to helping people fix their Portable Generators. Check it out on our site. https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
I have Generac GP8000E (G0069310) and the engine r - image-2fwsrbehqcya13uxwt41l5dc-1-0_8.jpg
Posted on Aug 19, 2019
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: portable generator low voltage
85 volts represents residual voltage. It is possible that your unit sat for an extended period and lost it's magnetism or the excitation system failed under load. check your manual for a procedure to "flash the field". If that is not successful, e-mail me and I'll tell you how to trouble shoot the failure.
Posted on Jan 04, 2009
Anonymous
  • 4 Answers
SOURCE: Low voltage output from inverter
I am thinking this a high impediance device problem and this is normal operation - the user manual of my inverter warns about use with high impediance devices - if not I am interested also...
Posted on Mar 03, 2009
Phil Rivera
  • 83 Answers
SOURCE: mitsubishi mgb 4000 wiring diagram
Here is a manual for a newer mge model. I don't think your going to find a manual on the older mgb around and they tend to be very similar from one model to another so it should help. Though you should be able to get parts.
http://www.mitsubishi-generators.com/pdf/540811+NM%20Products+MGE1801-2901-4000-4800-5800-6700.pdf
As for the gfci brand, I have not had any problems with any of the brands out there. So the cheapest is the best. The 30amp socket could be 110 or 220vac. If there is a selector switch on your machine. If not, there should be a NEMA number on the face of the socket (ie 15-5R). The R stands for receptical while a P stands for plug.
Here is a plug configuratio diagram that will help identify your plug and the voltage it puts out. These are standard so you can be sure that if it the same plug it will put out the same power. Be carefull to ensure which side is larger or has a tab is correct.
http://www.frentzandsons.com/Hardware%20References/plugandreceptacleconfiguratio.htm
While replacing the plug just swap wire for wire in the same place as your new plug. Gold connector to gold and silver to silver.
The inside of a small generator is very similar and if this don't help I can walk you through any connections you have questions on. Pictures would help if it comes to this.
Posted on Apr 02, 2009
Anonymous
  • 867 Answers
SOURCE: buffalo tools 4,000 watt generator
wow, that is high, i would think voltage regulator is faulty also
Posted on Aug 17, 2009
protek480
Craig Butler
  • 1730 Answers
SOURCE: ENGINE RUNS BUT NO POWER TO OUTLETS
When you flash the field, are you going + 12 volts to the top or right side brush? Negative to the other brush? Try three times for 2 seconds?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 26, 2009
We have a propane generator in motorhome, runs OK but no power, not even to the side switches.
This is going to require some testing with a volt meter. If you have one and some knowledge of how to use it, I may be able to help. The voltage regulator is responsible for putting voltage and current to the "excitation winding" in the generator. You will need to check for a blown fuse at the regulator, to start.
Oct 08, 2018 | Electrical Supplies
Why don't my generator fg7000ma generate power or only half power
Why a generator won't produce electricity?
After the unit is running, the generator rotational speed reaches the rated speed, the AC exciter stator excitation circuit switch is closed, the voltage regulator is raised to the maximum direction, at this time, the generator has no output voltage or the voltage is very low. That's why a generator fails to produce electricity.
May 31, 2015 | Electrical Supplies
Why does my honda generator start right up and will not generate power
Why generators do not generate electricity
1. Fault phenomenon
When the generator set speed reaches the rated speed, the AC exciter stator excitation circuit switch is closed and the voltage regulator is adjusted to the maximum value when the generator speed reaches the rated speed.
2. failure cause
The generator core remanence disappears or is too weak, the newly installed unit is disturbed by long-distance transportation or the generator is placed for too long, the generator core remanence disappears or the remanence inductance is weak, which results in the generator remanence voltage vanishing or less than the normal remanence voltage value. That is, the remanence voltage is less than 10 V, and the remanent phase voltage is less than 6 V. Because of the stator, rotor and AC exciter stator of synchronous generator, the core of rotor is usually made of 1mm-thick silicon steel sheet, which is subjected to vibration after excitation, and the remanence magnetic field is easy to disappear or weaken.
Aug 22, 2014 | Honda Eu2000i 2000w Generator
Alt has a small red wire in the plug. what is it for
The circuit it forms part of runs from the battery, throug hthe charge warning light on the dash, the the voltage regulator on the alternator. The wire does two jobs.
When the alternator is generating output, it fails to carry any current (sounds odd, but that's how it is) because there's a similar voltage at each end. As a result, the charge warning light on the dash goes out.
When the alternator is freshly spun up, current flows through this wire (sourced through the warning lamp) to provide the initial excitation for the alternator, allowing it to generate electricity. One the alternator is working, it uses its own power to create excitation.
A.
Apr 30, 2010 | 2000 Pontiac Grand Prix
No output voltage for powermate generator
NO. the capacitor resonates with a winding it is in parallel with as part of the voltage regulation.
Recharging a brushless generator can be tricky. I have had success using two 150 watt lamps in series between the running generator and the electric utility power. Search google for this method.
Apr 01, 2010 | Coleman Powermate Premium Plus 6250W...
5250 running watts output on 220 side is 300 volts, 120 side is 175 volts what is wrong
I can't tell you what type of rotor excitation you have without the model number but,
If its capacitor excited then you have a bad capacitor(s). If it has a voltage regulator then it could be bad or the sensing wires going to it are bad. If the unit is not sensing proper voltage its going to increase excitation thus causing your units voltage to be to high.
Nov 29, 2009 | Coleman Powermate Premium Plus 6250W...
My generator starts and runs great, It is not
  1. Check for any blown fuse and replace. It can be traced directly from the output lines.
  2. Check field excitation. The field excitation is supplied by the battery to the excitation coil through a pair of carbon brushes. If the brushes are worn out, no excitation field is supplied and no output is generated. Replace carbon brush if found worn-out.
  3. Use an analog multitester to check the continuity of the carbon brush and the field coil.
Sep 24, 2009 | Northstar Generator 18 Hp, 10,000 Watt,...
HONDA GENERATOR PROBLEM : SEPARATE MOTOR AND GENERATOR CONNECTED BY V BELT. MOTOR HAS TWO MODULES UNDER FLYWHEEL. ONE LOOKS LIKE ARMATURE THAT POSSIBLY SUPPLIES PRIMARY CURRENT TO THE HIGH VOLTAGE COIL---...
The armature (rotating field) is powered by the voltage regulator for 'excitation' which is the term describing a magnetic, revolving field. This magnetic field 'induces' voltage into the stator windings (stationary outer winding), producing voltage for use at the recepticles. Some older generators used a 'permanent magnet field, instead of using a powered winding from a regulator and the voltage and frequency were set by the RPM.
Frequency is still a function of RPM, but the voltage is controlled by the voltage regulator.
Aug 28, 2009 | Electrical Supplies
Does anyone know how to repair Genset generators? I have tested the windings, the diodes and capasitor all seem ok. threis not an AVR. when i excite the capasitor the voltage comes up but won't stay, but...
You need to check the exciter circuit for the gen field. If there isn't a voltage regulator, there is going to be a circuit feeding the field. It could even be a 'permanent magnet' rotor inducing the voltage for the stator.
Apr 10, 2009 | Yamaha 2500 Watt Industrial Inverter...
No 120 or 220 volts out put on portablegenerator motor runs good.
You should find out which wires are you excitation fields and flash them with a 9volt battery. That should make 120 volts
Apr 09, 2009 | Electrical Supplies
Electrical Supplies Logo
151 people viewed this question
Top Generac Electrical Supplies Experts
Bill Johnson
Fahr Quad
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
