Sounds like the timer connections are bad inside the timer . When you wiggle it it makes a connection most likely need a new timer most of them can't be repaired anymore they are very expensive . Check all the wires going to the timer for being loose & not making a good connection before ording one . Hope this helps
SOURCE: Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.
SOURCE: My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
SOURCE: Whirlpool Gold Ultimate Care II Electric Dryer
Hi, there sould be a two piece door catch. One piece on the door and another on the front panel that the door closes to. Look at the piece on the door. You will probably find it is bad. You can buy just that piece and change it. I hope this helps. If I can assist you further please let me know.
Thanks
Vic
SOURCE: I have a whirlpool gold ultimate care II heavy
You are probably hearing the timer count down, which means the timer is working right. This sounds more like your start switch is out. If you email or callus with your model number, we'll be sure to get the right parts out to you rigth away so you can get this repaired. We look forward to hearing back from you soon. Hope this answers your question.
SOURCE: I have a whirlpool dryer, model number lgt6634dq0.
HI. The timer will be the culprit here. The timer motor is damaged, and the cogs seem to be worn, as well. I recommend replacing this failed timer mechanism. Once replaced, the unit will operate correctly.
