Question about Kohler Home
Kohler r75791-2pc-na slow problem - Kohler Home
Posted by Venkat Danda on
How to get at ignition points
not with you
ignition points for a bath plumbing set ?
http://www.goldenwestpipe.com/category-s/1513.htm
are you asking about the igntier for gas tankless water heaters
May 20, 2016 | Kohler K-301-K-NA 3/4" Ceramic High-Flow...
Why exmark loses power when blades are turned on
Check for clogged deck.also inspection of mower deck belt. Check for glazing or cracks in belt. That will slow blades down.
Jul 28, 2014 | Kohler Engines NEW 25HP KOHLER ENGINE...
Cold water going through to hot side
Replace pressure balancing spindle part number 500520 from Kohler, if you purchased part Kohler warranty may cover issue, Kohler Customer Service 800-456-4537
Apr 09, 2014 | Kohler K-2971-KS-NA Hiflow Rite-Temp Valve...
How can i disassemble the sprayer handle on my kohler a112.18.1m kitchen faucet
1-800-4KOHLER
http://www.us.kohler.com/us/static/helpTopicsHelper.jsp?helpId=728
Aug 27, 2012 | Kohler Plumbing
Need to find proper carb needle valve settings for case 444 Kohler
This is the Kohler K321 engine.
You can find the service manual here: (14.16 mb)
http://www.kohlerengines.com/onlinecatalog/pdf/tp_2379.pdf
The inital carb adjustment setting procedures start on page 29
Kohler carb low idle 2 1/2 turns from closed Walbro carb 1 1/2 turn from closed
Kohler carb high idle 3 1/4 turns from closed Walbro carb NA
Thanks for choosing FixYa,
Kelly
Jul 08, 2011 | Garden
I have Kohler 3386-6 Rialto Skylight Round Front Toilet problem is that tank filling is very-very slow, perviously it used to fill in few seconds now it is taking 15 min. please let me know how can...
There is a screen @ the inlet to the vavle where the water connects that may be plugged or contact Kohler they will send you a repair kit for the fill valve.
Dec 12, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
I have many scratches on my kohler stainless sink.how do I remove them?
You would use rubbing compound -- same kind of stuff as used on autos -- there are different grits -- super fine on up, just like sandpaper. It'll tak a lot of rubbing. Probably good do a reasonable job with a buffer/etc. on a drill motor.
May 07, 2009 | Kohler BALLAD 25X22 Stainless Steel...
Home Logo
145 people viewed this question
Top Kohler Home Experts
john h
Bill Johnson
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
