Question about Hitachi Televison & Video
2007 Hitachi plasma tv model P50H401 turns on and has picture and sound then immediately “clicks” audibly and goes into standby mode. What needs to be replaced or repaired?
Posted by Amy Dinsmore on
5 Related Answers
Fujitsu
Martin Velazquez
  • 29 Answers
SOURCE: Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Posted on Nov 28, 2008
SOURCE: Hitachi P50H401 display problem
it is problem your TV high voltage unite(EHT)
change it by authorised service centre
Posted on Aug 28, 2009
Anonymous
SOURCE: Problem with Hitachi P50H401 Plasma TV - Will not
I have the same model, P50H401 and it developed the same problem two days ago. This set is 2 1/2 years old in service, being purchased in December 2007. The original manufacture date was October 2007.
The set was turned on and operating at the time and then promptly shut down by itself. The front blue LED power indicator began flashing four times in a loop or cycle.
The flashing LED sequence in this instance points to a problem with one of the following boards: PSU, X-Sus, Y-Sus or SDRs (there are two SDR boards, SDR-U and SDR-D, both are connected off of the Y-Sus board on the left hand side of the frame when rear facing). The set shuts down to prevent further damage to other boards or components.
I could power cycle the set but it would shut down after after a few seconds. Power LED would stay solid, I could hear the PS relays switching, and audio would output through the speakers. Then as the screen was just about to illuminate, the entire set would just shutdown. The blue LED would again go into the 4X flashing sequence.
I could not visually detect any signs of severe component damage on the main PS board. The two large electrolytic capacitors which have been mentioned as problematic in other threads seems fine. The where slightly raised on the top surface, but not blistered or completely blown open.
The only indication of component damage that I could detect visually was on one of the small surface mounted ICs on the SDR-U board.
Through reading other posts on this site, I learned that I was able to remove the suspect SDR-U board and then re-power the set. Doing this proved that the PS, X and Y Sus, and the SDR-D boards where o.k. The PS held, and the lower half of the screen illuminated. (I would only do this for as brief a period as required to determine if the the other boards would function and the screen would illuminate. Do not pro-long operation in this state so as to not cause further damage.)
It was somewhat difficult to locate the correct SDR-U board. My local service rep did not have one in stock, and the Canadian parts distributor was also out of stock. They estimated 10 - 14 business days to order one up from the U.S.A. (Hitachi closed their consumer electronics division in Canada back in 2009.)
By chance, I checked with another service rep in an adjacent town. He had a board for the P55. We did a visual comparison on the two boards and determined that it would be compatable.
The easy part was removing the defective SDR-U board and installing the replacement. The hard part was re-alinging the three ribbon tabs into the respective connectors on the SDR board. Be careful with these ribbons. The other end of each is fused to the plasma panel screen, so if you damage them, your screen is rendered useless.
I initially had the same problems as others have posted with having black or gray lines on the screen when the SDR-U was replaced. After gently adjusting the position of the ribbons as they are seated in the connectors, the lines disappeared. This was a slow and frustrating procedure, but it worked, Be patient.
Posted on Jul 03, 2010
Anonymous
  • 33 Answers
SOURCE: I have a Hitachi P50H401 plasma TV ,when you hit
unplug the unit for a while like one hour or so.
Posted on Sep 03, 2010
Jason Miller
  • 33 Answers
SOURCE: my hitachi P50H401 will not turn on. No sound no
check your sdr boards. you can test them with a multi meter. they are known for going bad. what happens is the two caps by the output go bad on the power supply and they make the sdr boards burn out. you can replace the two caps and save lots of money. then please check out this web page http://www.hometheatershack.com/forums/hitachi/38229-hitachi-p50h401-led-flashes-3-times.html
This web page has info about repairing these. The 4 flashing lights maybe the x sus or the y sus but it's still a good idea to check the sdr boards since its a common failer. I had one tv with a bad sdr board flash 3 time and another set it was flashing 4 times.
Posted on Feb 22, 2011
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
All of a sudden my Hitachi P50H401 has not been turning on. I simply plug it into an outlet and it turns on for 2 seconds then immediately shuts down (not even the red standby light stays on) . Any...
Hi.Your television have problem in power. maybe the power suply of your tv have loose connection or have open circuit and may contact sometimes when its move it.So you better check the power supply if is good or have output voltage.
Jul 05, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Aug 28, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Aug 31, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi tv please help
I write the same in other consult
Jul 09, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi 50" plasma no picture
how do i fix p50h401 blue light no picture and sound
Feb 07, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Televison & Video Logo
74 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
