2016 model
SOURCE: I DISCONNECTED BOTH THE TUB HOSE AND THE DRAIN
I have kenmore model# 417.98702890 how hard is it to replace water pump
SOURCE: My washer is not draining. Drain hose and hose
remove the 2 spring clips that hold the pump on the motor shaft and remove the pump,there has to be a blockage in the 2 impellers inside the unit if all else is clear,socks get pulled into there a lot of times
SOURCE: why does the ice bucket not drain into the hot tub!
Ice buckets don't normally drain into the hot tub water. They should drain externally. The drain pipe will go through the cabinet and exit the bottom close to the floor.... or at least that's how all the ice buckets I've encountered drain.
Regards,
Ian.
http://hottub.synthasite.com
SOURCE: i connected a hose extension
Andre, the problem lies in the length of the hose (should be no longer than 5 feet) and trying to drain it into the bath tub. Your dehumidifier relies entirely on gravity to drain. It will not drain upward over the edge of the bath tub. Water gets trapped in the hose, because of this and creates a blockage. When that happens, water is diverted back to the tank.
For continuous darinage, it should be into a floor drain or a sump. So unless yo have one of the aforementioned, continuous drainage is not an option for you.
Hope this helped you understand how it works and what your options are.
Most hot tubs have a low water cut off switch to protect the pump so it may be okay. A garden hose could have drained the water out overnight. Hope this helps.
Hi Rick Davis, I want to help you with your question, but I need more information from you.
Please Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7///
