Question about Kenmore Ovens
Manual for Kenmore oven model numberC970-441121
How to turn on self cleaning oven
5 Suggested Answers
Anonymous
SOURCE: oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Posted on Nov 18, 2008
Anonymous
SOURCE: self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Posted on Dec 09, 2008
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: I have locked my Kenmore self cleaning stove, now it won't open
Sorry you gave the sereial # for the oven. Need model #. Here is an manual that might work for you. cout and past in address bar.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0309524.pdf
Or you can go to this web sight and look up your oven.
http://www.managemyhome.com/mmh/answers/Answers.action#l4q106688
Good Luck
Posted on Dec 18, 2008
Anonymous
SOURCE: Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Posted on Aug 27, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Ultral Bake Self Cleaning Super Capacity electric oven
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Clean oven on kenmore range
LOCK OVEN DOOR AND TURN SELECTOR TO CLEAN. APPROX THREE HOURS LATER OVEN IS CLEAN. CLEAN UP ASHY RESIDUE.
Nov 10, 2013 | Kenmore Ovens
How do I clean Kenmore electric range model; 36393091300 .No manual for this self cleaning range.
Hi,Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 24, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
I need to know how to get a manual for a kenmore ultra bake self cleaning super capacity oven can you help me
Many Kenmore manuals are available from the Manage My Life site: http://www.managemylife.com/mmh/owner_manuals?intcmpMMHxG_HomexServices_Menu .
You will need the model number - there are over 9,000 ovens that come up when you search Kenmore Ultra bake self-cleaning super capacity oven. Most of the Kenmore ovens have the model and serial numbers on the front frame. (Left front of the frame on the lower oven on a dual oven model - just open the door and the panel should be visible.)
I hope this helps.
Jan 04, 2011 | Ovens
My kenmore self cleaning oven , F06 error
first try to turn the breaker off and then back on and see what happens.let me know if this helps and what is the model number?
May 10, 2010 | Ovens
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 | Ovens
I have a Kenmore Gas Oven, model # 911.30465864 and have lost the manual. I want to clean the oven, (it has self cleaning feature), but I am not sure if I can use oven cleaners in Gas Oven or not. Can...
Just use some easy off and do not use the self clean feature. Clean it the old fashioned way. Self clean ruins expensive electronics.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 20, 2010 | Ovens
Good Luck
Dec 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric stove
Hello d_i_a_n_a18,
In order to put most ovens into the self-clean mode, there are a series of steps that must be initiated in a specific order. On most units the oven control needs to be set to bake or clean and the temp. control needs to be set to clean and the door lock mechanism must be engaged for everything to work. I would suggest that you consult the user's manual for directions for your specific model. If your manual is not available, check on line at the kenmore parts web-site and you can usually get a PDF version of your manual. Good luck.
Nov 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Self cleaning oven directions
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
81 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Mike
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
