Question about Health & Beauty
SOURCE: can't find instructions for Homedics digital scales SC-390
EACH BUTTON IS FOR FOUR INDIVIDUAL USER. BUTTON ALLOWS YOU TO INPUT IDEAL WEIGHT (FOUR GOAL WEIGHTS FOR FOUR INDIVIDUAL USERS). AND CALCULATE AGAINST ONE OF THE FOUR INDIVIDUAL ACTUAL WEGHTS. i AM USER 1 IN MY FAMILY. I HIT THE 1 BUTTON, WEIGHT AND MY GOAL WEIGHT COMES UP BEFORE MY ACTUAL.
Posted on Mar 08, 2009
SOURCE: New Scale out of box will not weigh correctly
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
Posted on Jan 17, 2010
SOURCE: when set on lb,pounds, scale
Hi dogwalk564,
Make sure of the following:
Be sure to place the luggage in the dead center of the scale, this will distribute weight evenly across the scale, also try to keep it on a level floor, any slight incline or decline to a side of the scale, will give you a bad reading.
How do you know the scale is incorrect, how do you reference it to the current reading?
Kind Regards
JEDMEEYER1
* If this solution helped, please accept it
Posted on Aug 08, 2011
i repaired one that did not have batteries installed and ran on ac only the problem was in the power supply. it had a couple swollen capacitors they should be flat on top but bad when bulged out
Posted on Jul 08, 2012
SOURCE: digi weigh scale. Why does it indicate err every time I turn it on?
one of the sensors is out of calibration range,
Posted on Jul 26, 2015
Aug 16, 2014 | Heys USA SC400 Touch Scale
Jan 05, 2013 | Cars & Trucks
Mar 02, 2011 | Taylor Body Fat Analyzer & Scale, Model...
Sep 26, 2010 | Conair Thinner Scale by TH304 Glass Body...
Sep 02, 2010 | Salter 3007 Aquatronic Digital Scale
May 01, 2010 | Bernina Virtuosa 150
Dec 09, 2009 | Berkley Twist Lock Rod Rack
Jul 28, 2009 | Conair Thinner Scale by TH304 Glass Body...
Feb 01, 2009 | Health & Beauty
Nov 25, 2007 | Conair TAD1216PWT Digital Answering...
Feb 20, 2021 | The Health & Beauty
46 people viewed this question
