Question about Sharp Office Equipment & Supplies
My SHARP AR 5618 has a problem in printing . After printing a blank space appears in the middle of the page and is unable to copy that particular portion of the main paper
Posted by Rutuja Shirsekar on
  • Patrik Parker Jul 20, 2019
    Hi Rutuja Shirsekar, I want to help you with your question, but I need more information from you.
    Please call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7///
5 Related Answers
Cogz
Chris Coughlin
  • 1326 Answers
SOURCE: Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
Posted on May 21, 2008
Anonymous
  • 32 Answers
SOURCE: Sharp AR-287 Copier Paper Jam
most copiers that have lcd screens, should you show you where the paper is. sometimes it may take getting down to look under a couple of guide plates. or just roll some of the rollers to get the paper to come out. all it takes a minute piece of paper to be sitting on a sensor for it to throw the paper jam message.
Posted on Apr 02, 2009
Anonymous
SOURCE: Blank copies
Thanks Guest with Best Solultion! OMG! I have had my machine printing blank for over a month now and reading stuff and trying to find a solution. Until finally today I found this page. I read your solution and hit the front like u said for several times and nothing. Finally, after the third try WALA...IT WORKED!!! Thanks again. If anyone has this same problem try this because it really works! Eventhough this is such a strange problem for such an expensive machine.
Posted on May 18, 2009
M2Tech1
Andy Bell
  • 313 Answers
SOURCE: Sharp AR-5316 F5 ERROR
check the exsposure lamp this error relates to damaged or blown lamp also you check this when you turn th ecopier on you should see it self test at hte start up if there is no light it has blown or connections are bad
Posted on Jun 12, 2009
Anonymous
SOURCE: I am using Sharp AR-5316E copier (It makes noise)
Yes, Toner waste sump over filled; 100%!!! To confirm it, remove Toner cart. & make copy; I found same problem in Toshiba eStudio161, which is Sharp AR163, 5015, 5020 & 5316(all are same)
Posted on Jan 09, 2010
Light copy IN SHARP ar 5618d
I have a problem on sharp copier ar-5618 it copy is too light but it was printing white line before
Dec 01, 2013 | Office Equipment & Supplies
F2-64 on sharp AR-5318
sharp ar 5618 zerox machine in f2 64 error solution
Aug 04, 2012 | Office Equipment & Supplies
Sharp AR 5618S Error F2
Hope this help.
Hold down the copy start button
You will get F2 flash then 2 numbers will flash
http://www.manualslib.com/manual/902246/Sharp-Ar-5618.html?page=55#manual
Jul 06, 2012 | Sharp Office Equipment & Supplies
Need to know how to add developer power to a sharp ar-208d. my copies are all coming out blank
No need developer.When your machine need developer,it show developer signal.blank page print means,charger problem please check corona wear may be it broken or displace.
Jan 07, 2010 | Sharp AR-208D Printer
Problem with sharp ar168d
If you do not have developer in the machine it will not print. let me know if you have it or not.
Nov 14, 2007 | Sharp AR-M455N Copier
AR-M455 Printing Blank Pages
hi im jules_09.try checking the transfer roller or the drum charge roller or charge wire both of this unit are responsible for blank copy.either there id a current leak on those parts or your drum and transfer power pack is deffective.is the opc drum not expose to light morethan 8minutes?just check the transfer unit then the drum charge wire or roller
Nov 05, 2007 | Sharp AR-M455N Copier
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
