Question about Electrical Supplies
94 holiday rambler. Major electrical issue. Stairs quit working, generator won't start (just clicks). If I try to level with hydraulic jacks. Lights go out and a/c power shuts off. Engine starts
Posted by Martin Towne on
sherlywang
    Master:
  • Electrical S... Master
  • 425 Answers
If you need Cummins genset or Perkins genset, please visit website: www.dieselgeneratortech.com.
Posted on Oct 15, 2019
5 Related Answers
Juan Guillen
  • 373 Answers
SOURCE: 94 buick lesabre security light flashing
Ok..
Your vehicle is equipaded with Factory Anti Theft System.
Called Pass key II . If the mechanic found the Code
Pass key error....
Is there a few test to Do. to know exactly the problem.
1--- check if the Old and New key Are equipaded with a Little thing (Chip or Ressistence) in the center of the key.
If not you need a key with the chip. and the correct Ohms.
2. If you just replace the battery,
Full charge the battery Attemp to start the vehicle and leave the key in run position for exactly 11 Minutes, Them turn the key to off position for 30 seconds and try to start, if the vehicle start . you did the prosses to program the key.
If the vehicle not start.
Some times this procedure will require Up to 3 times to setup.
Or more with intervals of 30 minutes,, But if not start.
Remove the lower cover of the steering column. and the the Connector orange with 2 white wires shielded with a orange cover.
NOTE.. Be sure to not Confuse with the Yellow wires and connector, They are for the AIR BAG. Dont use a Convencinal Test light on any of the Mentionated wires....
After you find the wire and saw everything ok.
3-- You will need to remove the Ignition Lock cylinder.
The ignition lock cylinder is use 2 white wires shielded with orange cover, On 90% of the cases one of the wires come broken. and the ECM loss the comunication with the Chip incrusted in the key..
Posted on Dec 27, 2008
Richard Scordino
  • 6982 Answers
SOURCE: 1979 Holiday Rambler Engine with Ford 460 stops when it gets hot
You haven't given enough info to make a real diagnosis: Does it crank but not start or does it not crank. Ill take a guess: If the problem is not cranking hot, older ford starters used paper insulation that deteriorates over time. this will cause poor starter operation when hot, which usually is better cold. If problem is not with starter, next place I'd check is the ignition coil.
I could be wrong on both though...not enough info from you!
good luck
Posted on Mar 31, 2009
Anonymous
  • 27 Answers
SOURCE: Lost all electrical power while driving?
Sounds like a poor connection from either the positive or ground from the battery. Check connections at the battery, follow the cables to see if any other connections are loose.
Posted on Jun 24, 2009
Anonymous
  • 5 Answers
SOURCE: 1995 holiday rambler class A motorhome. e4od
clean out your engine
Posted on Aug 30, 2009
Terry May
  • 118 Answers
SOURCE: car wont start makes a clicking noise and resets the clock everytime
Does the battery have a good charge in it. Possible bad starter to.
Posted on Jun 13, 2012
I need a 2008 holiday rambler workhorse manul
Request the manual directly from Holiday Rambler.
Oct 02, 2018 | Holiday Rambler RVs
My holiday Rambler 2016 admiral XL keeps losing charge in the start up battery what is causing it
We dare not present with you at your location, so we can only guess, but here are some thoughts.
1) You may have a bad battery. Have it checked.
2) You may have a current draw, like for some item that uses electricity all the time.
For example, an electric clock, a TV set, a burglar alarm, a smoke/carbon-monoxide alarm.
3) You may choose to install a manual "shut -off" switch in your system that will shut off all electricity when you are not using the RV.
God bless your efforts.
May 11, 2018 | Holiday Rambler RVs
How do i change the hydraulic lift reservoir on a 2002 holiday rambler vacationer
drain reservoir remove hoses change tank then hook up fill with fluid then try to bleed each lift jack if needed if no air gets into pump
Dec 07, 2017 | Holiday Rambler RVs
Where is the smart wheel module on my holiday rambler scepor
Contact Holiday Rambler directly or your local Holiday Rambler dealer: https://www.holidayrambler.com/contact
Aug 05, 2017 | Holiday Rambler RVs
2001 holiday rambler endeavor have lost all lights in side. Plugins still work tvs and fridge
So, you have lost your 12V power, but you still have 120V power. In an electrical distribution panel, probably in an outside compartment near the drivers seat, there is an electrical solenoid switch that may not be working. If you can use a test meter, see if you have power at that switch. I That solenoid does go bad sometimes on Holiday Ramblers and Monacos. You can temporarily bypass that panel switch by joining the 2 heavy wires together and see if you then have lights, etc. And, be sure that you have your 12V house switch in the on position, in the battery compartment and that the switch near the door is turned on.
Feb 20, 2017 | Holiday Rambler RVs
John Deere 310G that the hydraulics quit working
You just go to the link I attached I'm sure you will get the solution of your problem.
John Deere 310G
May 29, 2017 | John Deere Garden
Electrical Supplies Logo
135 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
