Question about LG Washing Machines
My LG dishwasher started stopping towards end of cycle and the OE error code was displayed. I changed to a different wash mode and it would work, then same thing started happening with the other cycles. We checked hose and no kinks or blockages. If i press the drain buttons, the dishwasher drains fine. Can't imagine it being the drain pump if it drains when i press the drain only feature. It's only towards the end of the cycle. It stops and displays OE. What can be the problem? Thanks.
Posted by Naoemi Nippes on
Tom Chichester
    Top Expert:
  • LG Master
  • 55,379 Answers
Could be a defective cycle timer
Posted on Dec 19, 2019
5 Related Answers
Mukesh Kumar
  • 3230 Answers
SOURCE: lg - LDS5811ST Dishwasher OE Error Code
hi
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Posted on May 06, 2009
Anonymous
SOURCE: For LG WM2233HW, Error Code OE. Already check
Replace the water pump. Because the water can not pump out, the machine idles for a while then stops with the error code OE. The technician said, the drain hose should be hang high before curse down to the drainage so air can not go to the hose.
Posted on Jun 24, 2009
praky16
Prakash Ram
  • 744 Answers
SOURCE: lg tromm wm2277hs stops when it gets to the rinse
hi
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Check inlet valve operation
  • If there is water in the unit:
    1. Check Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Check there is not a siphon problem
  • Check wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Check pressure switch operation
  • Check flow meter operation
Posted on Jul 24, 2009
Anonymous
  • 136 Answers
SOURCE: my washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Posted on Jan 18, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: LG WM2277 "OE" ERROR. PLEASE HELP
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!
Posted on Sep 15, 2010
OE error please
There may be a few different reasons why the OE error code can display on your washing machine. Is it the LG washer getting the OE error code? The OE error code on the LG washing machine display is an indication of a NO DRAIN issue. The 3 issues that may cause this fault code is a bent drain hose, the drain pump filter is blocked, or the drain pump may have foreign objects lodged in it making it unable to drain. All these issues can cause your LG washer to display the error code OE. With all these different reasons, checking all 3 components will clear the error and fix your LG washing machine.
Oct 29, 2017 | Washing Machines
What are the common fixes for OE Error Code?
OE error code is an Outlet Error.
That has to do with the drain itself. It can come up when the unit is draining slowly, it has nothing to do with water-level really. I would suggest makign sure that your drain hose is not crimped / crushed / or obstructed first before going onto other problems.
May 02, 2014 | Samsung DMR77LHS Tall Tub Dishwasher
My washing machine showing an OE error before end of cycle
Jan 18, 2010 | LG WM-2277HW Front Load Washer
Jan 12, 2010 | LG WM-2277HW Front Load Washer
Error Code OE
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
My LG Clothes Washer has stopped mid cycle and is displaying an "OE" error code. How do I get the machine to finish the cycle?
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error code LE and OE
Apr 12, 2009 | LG LDF8812 Stainless Steel Built-in...
OE fault displayed on spin cycle LG 1019BD 10KG WASHING MACHINE
Jan 29, 2009 | Washing Machines
Washing Machines Logo
970 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
