Question about Coleman Electrical Supplies
What is the resale value on a Coleman powermate 1850 pulse generator?
Posted by Wayne R Johnson on
Carl Rock
  • Coleman Master
  • 2,388 Answers
Figure 4 to 8 cents a watt depending on condition. So $75 (runs but may need carb work) to $150 (like new).
If engine wont run or no AC output, value $0.
Posted on Oct 12, 2019
  • Carl Rock
    Carl Rock Oct 12, 2019
sherlywang
    Master:
  • 425 Answers
How is the quality?
The resale value depends on the situation of your generator.
If you need to have a diesel generator set, please visit website: www.dieselgeneratortech.com
Posted on Oct 09, 2019
5 Related Answers
Anonymous
SOURCE: I have a Coleman Powermate Pulse 1850 Generator.
If the generator hasn't been used for awhile the rotor may have lost it's magnetism. All you need is to re-excite it. There are several websites that explain how to do this. It's a good place to start.
Erick
Posted on Apr 04, 2009
Anonymous
SOURCE: pull start recoil assembly
I bought a replacement recoil starter for my 1850 at Pats small engine parts. The part number for a 3.5 B & S is 499706. If you look on the heat shield on the side of the motor there is the engine model and s/n. Hope this helps.
Posted on Jun 12, 2009
Anonymous
  • 9 Answers
SOURCE: Need manual for coleman powermate 1850 generator
google it! use the specific search terms, Coleman power pulse 1850 - it worked for me!
Posted on Jun 19, 2009
Anonymous
SOURCE: What oil do I use in a Coleman Powermate 1850
Even though Powermate generators are discontinued they still have a website with owners manuals at www.powermate.com.
Posted on Sep 30, 2009
Anonymous
  • 243 Answers
SOURCE: coleman sport 1850 powermate generator, no fire to sparkplug
is there an oilprotection on the gen. disconnect the cable and try again
Posted on Feb 10, 2010
My older Coleman Powermate Pulse 1850 is leaking gas from the grommet that connects the hose to the tank. I cannot get needle nose plyers inside the tank to tighten the nut (if there even IS a threaded nut...
I don't think there is any way to tighten or repair leak other then by replacing grommet. sorry I'm not much help but coleman powermate is no longer in business and I have had no sucess in finding a source for parts for you.Thank you and good luck.
Feb 24, 2011 | Coleman 1850 Watts Generator Each...
I have a coleman powermate pulse 1800ex generator. It stutters when put in the run position. when in the choke position it doesnt stutter.
your main jet is plugged shut off fuel, remove bowl from carb(bottom of bowl) clean out small holes on screw with stranded wire .2 holes on side on in middle. be sure to put fiber washer back between main jet and bowl and use fresh gas jor
Jan 11, 2011 | Coleman 1850 Watts Generator Each...
Coleman sport 1850 powermate generator, no fire to sparkplug
Jan 18, 2010 | Coleman Sport 1850 Generator
What oil do I use in a Coleman Powermate 1850 generator?
Sep 29, 2009 | Coleman Powermate Powermate 5000W...
Jun 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Pull start recoil assembly
May 31, 2009 | Coleman Powermate Powermate 5000W...
Erick
Mar 23, 2009 | Coleman Electrical Supplies
Electrical Supplies Logo
128 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
john h
Tim Venetis
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
