Question about Braun Health & Beauty
Braun silk epil not rotating.
I've replaced the battery and cleaned the unit already. When I take the head off and switch it on the little rotating thing inside spins fine, but as soon as I put the head back on it stops rotating.
Posted by Amy Feetham on
2 Related Answers
Anonymous
SOURCE: Broke my Braun Silk Epil Xpressive
Hey , were your able to find any solution for your problem. I opened my epilator and now this wire is not in its place. I dont remember how it used to be :(
Posted on Dec 12, 2011
Anonymous
SOURCE: My Silk Epil 7 has
My Braun worked fine the last time I used it & would not come on when I tried it today. Worked on it & found it to be jammed with hair. Would not rotate. Scrubbed it with a toothbrush, started digging out the hair, forced it to rotate, scrubbed it some more, & rotated it some more. The more I worked with it the more hair kept coming out. It's rotating fine now. I think I'm going to clean it with my water pik. My Braun is the kind that can be used with water & the top part comes off. Haven't used it yet but I think I have fixed it. Wish I could get it apart to clean it out but the head of the screw is strange & I don't have anything that will turn it.
Posted on Dec 30, 2011
1helpful
Why is my epilator not charging?
Same problem. Only after 2 months of buying silk epil 7 epilator, it stopped charging and is not working at all. There is very few customer service centres of Braun in India. So it is very difficult to contact them and show your product to find out the issue.
Braun Troubleshooting
The rechargeable battery inside unit has reached the end of its usefulness and needs to be replaced.
4helpful
3answers
My Silk Epil 7 has stopped working, the epillator head has stopped rotating. I doubt that some hair has got stuck inside. Could ypu please help?
Silk Epil 5376 Rotators are too slow and it doesn't work like it used to. When you take the head off the spinner spins fast but when you put the head back on it is slow and then the tweezing heads do...
You will need a star-shaped bit to remove the 2 screws. I would imagine they’re metric as it’s made in Germany. Barring that, a small flat head screwdriver used for eyeglasses will work. Remove the screws over a bucket or something so you don’t lose them, because they’re specific to the SilkEpil and can’t be bought at the hardware store.
When you remove the screws and take it apart, you’ll see the gears inside are clogged with hair. The flaw with the design is that the gear mechanism will suck in a few hairs every time you use it, which build up over time.
Remove the gear unit and use tweezers to pull out all the hair. You can rotate the gears to get it all. On the underside of the tweezer section, there’s a little recessed gear that’s probably clogged with hair too. Rotate the tweezer barrel to turn the little gear, and pull out the hair.
Give everything a good rinse, put it back together, and let it dry overnight. Presto, good as new!
I plan on doing this once a year as regular maintenance.
6helpful
The spring has fell out of the head when i was changing top i dont know how it goes back together
pull the black thing with the little blades until it detach, put the spring inside the hole, reassemble
Health & Beauty Logo
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Joseph Hoffmann
reference30
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
